Carb lines/ fuel rail/ regulator set up pics
#2474525
03/30/18 07:50 PM
03/30/18 07:50 PM
Posts: 1,467 Martinsville, IN
cdwmotorsports
Martinsville, IN
I need to see how guys feed the carb today from the regulator to the bowls. I am struggling with how I’m gonna mount this stuff
eBay-cdwmotorsports
Re: Carb lines/ fuel rail/ regulator set up pics
[Re: cdwmotorsports]
#2474599
03/30/18 10:31 PM
03/30/18 10:31 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I used an AED kit for a Holley/Quick Fuel regulator and it fits nice. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: sgcuda]
#2474678
03/31/18 12:40 AM
03/31/18 12:40 AM
Posts: 4,585 Motor City
6PKRTSE
Motor City
I made a bracket that mounts off of my upper water pump bolts.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
#2475899
04/02/18 10:30 AM
04/02/18 10:30 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
I also made a bracket to hold a fuel log to the front of the manifold.
#2476585
04/03/18 01:03 AM
04/03/18 01:03 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
For those who have mounted their regulators in front of the Intake are you not concerned with the fuel gettingnto hot ? Are you running regulators that return the excess fuel to the tank?
My simple Holley regulator is on the passenger inner fender. I had planned to run a single Holley but switched to a tunnel ram and 450 holleys which have their fuel Inlet’s on the driver side. Drivers side is pretty busy with other stuff not sure I can relocate the regulator over there.
[Re: NTOLERANCE]
#2476664
04/03/18 10:21 AM
04/03/18 10:21 AM
an8sec70cuda
It's kinda hard to see, but my log has a -10 inlet on the passenger's side. The regulator on the driver's side end is the return, -8 back to the tank.
[Re: NTOLERANCE]
#2476736
04/03/18 01:13 PM
04/03/18 01:13 PM
Posts: 608 TN
1DGEMAN
TN
[quote=NTOLERANCE]For those who have mounted their regulators in front of the Intake are you not concerned with the fuel gettingnto hot ? Are you running regulators that return the excess fuel to the tank?
I expect that you pick up less heat running the fuel lines in from the front rather than over the top of a hot header.
Real Men shift for themselves
#2477417
04/04/18 03:23 PM
04/04/18 03:23 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Mine's a little different. -8 feed -10 return.with the regulator at the rear . Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
