Drive shaft free play??? #2474523
03/30/18 07:48 PM
03/30/18 07:48 PM
Btween a rock and a hard place
moparlulu Offline OP
Finishing up changing out the rear from a 8 3/4 to a Dana 60. as it stands, I have close to a half inch of play from the yoke bottoming in the transmission. Is this enuff play???? 68 Charger sitting on Caltrac mono leafs and bars.
Re: Drive shaft free play??? [Re: moparlulu] #2474529
03/30/18 08:00 PM
03/30/18 08:00 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I wouldn't run less than 3/4", but 1" is better.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Drive shaft free play??? [Re: moparlulu] #2474534
03/30/18 08:10 PM
03/30/18 08:10 PM
AndyF Offline
AndyF  Offline
Is that the minimum free play? If so that is enough. If that is the free play at ride height then you need to check it with the suspension moving to make sure it doesn't bottom out at some point.
Re: Drive shaft free play??? [Re: moparlulu] #2474592
03/30/18 10:18 PM
03/30/18 10:18 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Unknowingly I've run mine at 1/4" with no trouble. Didn't realize it was that tight since the car's tightest spot is at ride height.
Doug
Re: Drive shaft free play??? [Re: moparlulu] #2474735
03/31/18 03:04 AM
03/31/18 03:04 AM
AndyF Offline
AndyF  Offline
If the tightest point still has 1/4 inch of travel then I'd think that is enough unless the suspension and/or the engine mounts have a lot of play in it.
If the endplay gets too tight then it can be difficult to remove the driveshaft. There has to be room to move the driveshaft forward so it can come out of the pinion yoke.
Re: Drive shaft free play??? [Re: moparlulu] #2474742
03/31/18 03:39 AM
03/31/18 03:39 AM
That's at the tightest points of travel. the most looks to be about 3/4". Looks like I should be good! Thanks for the confirmation guys!
Re: Drive shaft free play??? [Re: moparlulu] #2474744
03/31/18 03:43 AM
03/31/18 03:43 AM
Add weight into the trunk to compress the suspension a lot more just to be safe twocents
All the Mopars I have work on get closer with the suspension loaded down, they get more driveshaft end play when the suspension is extended like under hard acceleration scope
Re: Drive shaft free play??? [Re: AndyF] #2474979
03/31/18 06:35 PM
03/31/18 06:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That's my thought too, since the u-joint cups are around 1 inch in diameter.
Re: Drive shaft free play??? [Re: moparlulu] #2475059
03/31/18 08:41 PM
03/31/18 08:41 PM
AndyF Offline
AndyF  Offline
Yeah I made that mistake on my Duster since it was the first car I did with Calvert springs. My Coronet has super stock springs and they droop down a long way and pull the driveshaft with them. The Calvert springs don't have much droop to them so the driveshaft doesn't pull out of the trans very far. I had a hard time wiggling the driveshaft out of the Duster since I had set it up the same way as on my Coronet.
