79 D150 Ignition Switch #2468075
03/18/18 12:41 PM
03/18/18 12:41 PM
85086
moparpollack Offline OP
Lil Herman
Lil Herman
85086
Need a source for the ignition switch with a tilt column. The non-tilt is a common switch but the tilt part number isn't even listed. help
Re: 79 D150 Ignition Switch [Re: moparpollack] #2468139
03/18/18 03:58 PM
03/18/18 03:58 PM
Central Florida
larrymopar360 Online content
Stud Muffin
larrymopar360  Online Content
Stud Muffin
Central Florida
https://www.rockauto.com/en/catalog/dodge,1979,w150+pickup,5.9l+360cid+v8,1099841,electrical-switch+&+relay,ignition+starter+switch,4700
Facts are stubborn things.
Re: 79 D150 Ignition Switch [Re: moparpollack] #2468142
03/18/18 04:01 PM
03/18/18 04:01 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
NOS Mopar
https://www.ebay.com/itm/NOS-MOPAR-1978-80-DODGE-TRUCK-COLUMN-IGNITION-SWITCH-3747199/142407709273?epid=14002653870&hash=item2128293259:g:7M0AAOSw8lpZOB9w&vxp=mtr
https://www.ebay.com/itm/1978-87-DODGE-TRUCK-RAMCHARGER-POWER-WAGON-TILT-WHEEL-IGNITION-SWITCH-NOS-1217/401466264549?hash=item5d79410be5:g:AAoAAOSwTm9aODea&vxp=mtr
Re: 79 D150 Ignition Switch [Re: larrymopar360] #2468302
03/18/18 09:07 PM
03/18/18 09:07 PM
85086
Lil Herman
Lil Herman
85086
Larry, thanks for the help but it's the pigtail and switch activated by the key that goes to this switch I need. help
Re: 79 D150 Ignition Switch [Re: moparpollack] #2468314
03/18/18 09:31 PM
03/18/18 09:31 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I saw the non-tilt ones that had some type of harness but none with the tilt ones. I don't know.
This comes up with non-tilt
Re: 79 D150 Ignition Switch [Re: moparpollack] #2468316
03/18/18 09:39 PM
03/18/18 09:39 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Everything for '79 D150 WITH tilt looks like this
Re: 79 D150 Ignition Switch [Re: larrymopar360] #2468333
03/18/18 10:15 PM
03/18/18 10:15 PM
85086
Lil Herman
Lil Herman
85086
Same part that I need but for a tilt column, probably because of the different switch. shruggy
Re: 79 D150 Ignition Switch [Re: moparpollack] #2468344
03/18/18 10:40 PM
03/18/18 10:40 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
The Rockauto one above is for tilt. All the ones that look like the one I posted with harness state "non-tilt" so I don't get it either.
Re: 79 D150 Ignition Switch [Re: moparpollack] #2468357
03/18/18 11:05 PM
03/18/18 11:05 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
If you need the switch you need the part he posted, if you need the mechanism that operates the switch, that's a whole 'nother animal.
Re: 79 D150 Ignition Switch [Re: moparpollack] #2468363
03/18/18 11:12 PM
03/18/18 11:12 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The tilt is for sure, a delco style column-switch but that does not mean a chevy switch will work. I'm thinking it's similar and I don't know how hard it will be to obtain, but it is surely different from the straight column style.
Re: 79 D150 Ignition Switch [Re: buildanother] #2468381
03/18/18 11:45 PM
03/18/18 11:45 PM
85086
Lil Herman
Lil Herman
85086
Yes the deco style has me wondering if a GM type might be an option.
Re: 79 D150 Ignition Switch [Re: moparpollack] #2468401
03/19/18 12:15 AM
03/19/18 12:15 AM
md
mopars4ever Offline
mopars4ever  Offline
md
autozone shows this for tilt Part Number: LS420
Re: 79 D150 Ignition Switch [Re: mopars4ever] #2468414
03/19/18 12:39 AM
03/19/18 12:39 AM
chicagoland,usa
chicagoland,usa
...and Advance shows BWD # CS89.
Re: 79 D150 Ignition Switch [Re: moparpollack] #2468821
03/19/18 10:50 PM
03/19/18 10:50 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The key in the column on a tilt pulls a rod that connects to the switch under the dash that is attached to the column with two screws.
Do you need the lock & rod assembly? Or the switch attached to the column under the dash? Or the wiring connector(s)? ( Older harnesses had 1 connector, newer there are 2 connections that plug into the switch). Both connectors (one piece or two piece) are part of the dash harness. Gene
Re: 79 D150 Ignition Switch [Re: mopars4ever] #2469095
03/20/18 01:20 PM
03/20/18 01:20 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Which looks exactly like the one I posted from Rockauto
