79 D150 Ignition Switch
#2468075
03/18/18 12:41 PM
03/18/18 12:41 PM
moparpollack
Lil Herman
Lil Herman
85086
Need a source for the ignition switch with a tilt column. The non-tilt is a common switch but the tilt part number isn't even listed.
Re: 79 D150 Ignition Switch
[Re: moparpollack]
#2468139
03/18/18 03:58 PM
03/18/18 03:58 PM
Posts: 15,887 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
https://www.rockauto.com/en/catalog/dodge,1979,w150+pickup,5.9l+360cid+v8,1099841,electrical-switch+&+relay,ignition+starter+switch,4700
Facts are stubborn things.
[Re: moparpollack]
#2468142
03/18/18 04:01 PM
03/18/18 04:01 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
NOS Mopar
https://www.ebay.com/itm/NOS-MOPAR-1978-80-DODGE-TRUCK-COLUMN-IGNITION-SWITCH-3747199/142407709273?epid=14002653870&hash=item2128293259:g:7M0AAOSw8lpZOB9w&vxp=mtr
https://www.ebay.com/itm/1978-87-DODGE-TRUCK-RAMCHARGER-POWER-WAGON-TILT-WHEEL-IGNITION-SWITCH-NOS-1217/401466264549?hash=item5d79410be5:g:AAoAAOSwTm9aODea&vxp=mtr
[Re: larrymopar360]
#2468302
03/18/18 09:07 PM
03/18/18 09:07 PM
moparpollack
Lil Herman
Lil Herman
85086
Larry, thanks for the help but it's the pigtail and switch activated by the key that goes to this switch I need.
[Re: moparpollack]
#2468314
03/18/18 09:31 PM
03/18/18 09:31 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I saw the non-tilt ones that had some type of harness but none with the tilt ones. I don't know.
This comes up with non-tilt
[Re: larrymopar360]
#2468333
03/18/18 10:15 PM
03/18/18 10:15 PM
moparpollack
Lil Herman
Lil Herman
85086
This comes up with non-tilt Same part that I need but for a tilt column, probably because of the different switch.
[Re: moparpollack]
#2468344
03/18/18 10:40 PM
03/18/18 10:40 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
The Rockauto one above is for tilt. All the ones that look like the one I posted with harness state "non-tilt" so I don't get it either.
[Re: buildanother]
#2468381
03/18/18 11:45 PM
03/18/18 11:45 PM
moparpollack
Lil Herman
Lil Herman
85086
The tilt is for sure, a delco style column-switch but that does not mean a chevy switch will work. I'm thinking it's similar and I don't know how hard it will be to obtain, but it is surely different from the straight column style. Yes the deco style has me wondering if a GM type might be an option.
[Re: mopars4ever]
#2469095
03/20/18 01:20 PM
03/20/18 01:20 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
autozone shows this for tilt Part Number: LS420 Which looks exactly like the one I posted from Rockauto
