Flywheel and clutch question for 70-383. 4spd guru's. #246771
03/08/09 11:20 AM
03/08/09 11:20 AM
MO
cdp Offline OP
cdp  Offline OP
MO
I have no flywheel or clutch assembly and have noticed that there is 10.5 and an 11.0 clutch as well as 130 tooth and a 142 tooth.
Which, exactly, do I need? I have the correct #'s trans and bellhousing for my 70-Bee.
Should it have been a 10.5 or 11.0 from the factory? Is an 11.0" considered an upgrade?
Re: Flywheel and clutch question for 70-383. 4spd guru's. [Re: cdp] #246772
03/08/09 11:43 AM
03/08/09 11:43 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
10 1/2 clutch with 130 tooth flywheel
logan426
Re: Flywheel and clutch question for 70-383. 4spd guru's. [Re: MLR426] #246773
03/08/09 11:46 AM
03/08/09 11:46 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
If you need a good flywheel the 18 pound Mopar Performance is a good choice
Re: Flywheel and clutch question for 70-383. 4spd guru's. [Re: dart4forte] #246774
03/08/09 11:55 AM
03/08/09 11:55 AM
Kirkland, Washington
Pacnorthcuda Offline
Careful there! Lightweight flywheels are a compromise--yes they allow an engine to rev faster, but conversely they store less energy (the main function of a flywheel) and therefore require more throttle to get a car moving.
A heavy daily driver without mega torque/tall gears might not benifit from a lightweight FW.
Re: Flywheel and clutch question for 70-383. 4spd guru's. [Re: MLR426] #246775
03/08/09 11:57 AM
03/08/09 11:57 AM
logan426
Can't a 10.95" be used on a 130 tooth??? I thought it could.
Re: Flywheel and clutch question for 70-383. 4spd guru's. [Re: Pacnorthcuda] #246776
03/08/09 12:03 PM
03/08/09 12:03 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I have a 10.95 with a 130 tooth in my 70 Charger.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Flywheel and clutch question for 70-383. 4spd guru's. [Re: 70sixpkrt] #246777
03/08/09 12:20 PM
03/08/09 12:20 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
10.95 and 10.5 both fit the 130 flywheel.Just make sure the bell is for a 130 wheel.The 10.9 uses small head bolts.Rocky
Chrysler Firepower
Re: Flywheel and clutch question for 70-383. 4spd guru's. [Re: therocks] #246778
03/08/09 12:25 PM
03/08/09 12:25 PM
MO
cdp Offline OP
cdp  Offline OP
MO
I don't have the part # handy, but the bell housings lists as a 1970 383/440/hemi.
Re: Flywheel and clutch question for 70-383. 4spd guru's. [Re: cdp] #246779
03/08/09 06:33 PM
03/08/09 06:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It would be the 513 bell and it takes the 130 tooth wheel .
