Just a couple of simple electrical questions, please... #2466731
03/15/18 01:27 AM
03/15/18 01:27 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
* With points type ignitions, does the black wire from the distributor connect to the NEG side of the coil?
* On applications using a 2 prong ballast resistor, can a 4 prong resistor be substituted if a 2 prong is not available? I'm wondering if one spade from each side would work.
I rarely have worked on points type cars, only the factory electronics or a converted car.
Thank you.
Re: Just a couple of simple electrical questions, please... [Re: Kern Dog] #2466734
03/15/18 01:32 AM
03/15/18 01:32 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yes, on the black wire. I've never worked on a car with the four-pin ballast, but my understanding is that it is just two separate resistors in one package. Each resistor has a different resistance. I believe you would want to use the one with the least resistance.
Re: Just a couple of simple electrical questions, please... [Re: Jim_Lusk] #2466816
03/15/18 10:42 AM
03/15/18 10:42 AM
Correct, use the lengthwise pair that has the least resistance. Last one I checked had 1.6 ohms on that side. I'd start with a .017" gap/lube the cam sparingly/clean the surfaces with contact cleaner/brake kleen. confirm the dist upper shaft radial play is acceptable.
Re: Just a couple of simple electrical questions, please... [Re: Kern Dog] #2466923
03/15/18 03:08 PM
03/15/18 03:08 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yes and yes, and as mentioned, use the lower resistor path on the 4 prongs one ( usually they are on 1 to 1.5 ohms rate ). The higher resiostor path is around 4.5 to 5 ohms
Re: Just a couple of simple electrical questions, please... [Re: NachoRT74] #2467023
03/15/18 07:05 PM
03/15/18 07:05 PM
& you can parallel connect both sides & see what you get. one end is already (OE) jumped across sideways with the blue loop of wire & do the same to the other end then see what you get & my last one was 1.1 ohms & whether this lower amt will work for you depends on the quality of the point set & the coil pri ohms you are useing (post what you are useing). As you know lower, gives a hotter spark/less longevity (& vice versa).
Re: Just a couple of simple electrical questions, please... [Re: Kern Dog] #2467059
03/15/18 08:31 PM
03/15/18 08:31 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Thanks. I would only use the 4 prong if I did not have the correct 2 prong one nearby. The MSD ballast with the Blaster 2 coil was .06 ohms.
Re: Just a couple of simple electrical questions, please... [Re: Kern Dog] #2467061
03/15/18 08:34 PM
03/15/18 08:34 PM
If the recommended MSD ballast is 0.06 ohms then I would definitely parallel the 4 prong as you will be above that. Question, is MSD saying the blaster 2 coil/0.06 ohm ballast will work fine with points?
Re: Just a couple of simple electrical questions, please... [Re: Kern Dog] #2467064
03/15/18 08:41 PM
03/15/18 08:41 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
good question.
Use the recommended resistance based on the type of ignition system this is for. If its a points triggering an MSD or such, it will be different than running points that are carrying the coil's primary current.
