I believe you would want to use the one with the least resistance.
Correct, use the lengthwise pair that has the least resistance. Last one I checked had 1.6 ohms on that side. I'd start with a .017" gap/lube the cam sparingly/clean the surfaces with contact cleaner/brake kleen. confirm the dist upper shaft radial play is acceptable.
