yes and yes, and as mentioned, use the lower resistor path on the 4 prongs one ( usually they are on 1 to 1.5 ohms rate ). The higher resiostor path is around 4.5 to 5 ohms
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
