Re: Just a couple of simple electrical questions, please...
[Re: Jim_Lusk]
#2466816
03/15/18 10:42 AM
03/15/18 10:42 AM
RapidRobert
I believe you would want to use the one with the least resistance. Correct, use the lengthwise pair that has the least resistance. Last one I checked had 1.6 ohms on that side. I'd start with a .017" gap/lube the cam sparingly/clean the surfaces with contact cleaner/brake kleen. confirm the dist upper shaft radial play is acceptable.
[Re: Kern Dog]
#2466923
03/15/18 03:08 PM
03/15/18 03:08 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
yes and yes, and as mentioned, use the lower resistor path on the 4 prongs one ( usually they are on 1 to 1.5 ohms rate ). The higher resiostor path is around 4.5 to 5 ohms
[Re: NachoRT74]
#2467023
03/15/18 07:05 PM
03/15/18 07:05 PM
RapidRobert
& you can parallel connect both sides & see what you get. one end is already (OE) jumped across sideways with the blue loop of wire & do the same to the other end then see what you get & my last one was 1.1 ohms & whether this lower amt will work for you depends on the quality of the point set & the coil pri ohms you are useing (post what you are useing). As you know lower, gives a hotter spark/less longevity (& vice versa).
[Re: Kern Dog]
#2467061
03/15/18 08:34 PM
03/15/18 08:34 PM
RapidRobert
If the recommended MSD ballast is 0.06 ohms then I would definitely parallel the 4 prong as you will be above that. Question, is MSD saying the blaster 2 coil/0.06 ohm ballast will work fine with points?
