69 Charger rear suspension front pivot bolt #2464737
03/11/18 02:10 PM
03/11/18 02:10 PM
NC
Sixt8Chrgr Offline OP
NC
Prior to disassembly of my car the pivot bolt nut was outboard. I have good reason to believe that this was the way the car was originally assembled. (I have original springs etc on the car and I have known the car since I was 16.) When we put the rear suspension back in the car the pivot bolt nut is inboard. I can see the head of the bolt from the side of the front hanger. Which is correct? The CSM has the head outboard.
Re: 69 Charger rear suspension front pivot bolt [Re: Sixt8Chrgr] #2465041
03/12/18 12:56 AM
03/12/18 12:56 AM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
my originals on my car that my grand pop had since new was the nuts on the outboard side.
inherited a 69 roadrunner from my grand pop.
Re: 69 Charger rear suspension front pivot bolt [Re: fuelishnsilly] #2465136
03/12/18 11:16 AM
03/12/18 11:16 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Correct, that way if the nut falls off/rusts off the stud is trapped by the frame and cannot fall out of the front perch
Re: 69 Charger rear suspension front pivot bolt [Re: DAYCLONA] #2465436
03/12/18 09:41 PM
03/12/18 09:41 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 69 Charger rear suspension front pivot bolt [Re: Sixt8Chrgr] #2465512
03/12/18 10:59 PM
03/12/18 10:59 PM
NC
NC
Dayclona is that drawing for a B Body?
This is from my Service Manual. I still think the nut should be outboard but this drawing begs to differ?
Re: 69 Charger rear suspension front pivot bolt [Re: Sixt8Chrgr] #2465516
03/12/18 11:05 PM
03/12/18 11:05 PM
NC
NC
This is a little easier to see. This is from the 69 Service Manual. Seems like the bolt head is on the outboard side, but like I said before I restored my car I have pics of the nut being outboard. Any ideas what is correct?
Re: 69 Charger rear suspension front pivot bolt [Re: Sixt8Chrgr] #2467731
03/17/18 01:55 PM
03/17/18 01:55 PM
New York, USA
Chargerfan68 Offline
New York, USA
On my 68 Charger, i know the bolts were installed from the inside because i can see the imprint of the bolt heads in the undercoating next to the bolt head on the adjacent rail. When they were putting the nuts on, the bolts must have pushed out and pressed into the inner frame rails making a perfect impression in the factory undercoating.
Re: 69 Charger rear suspension front pivot bolt [Re: Sixt8Chrgr] #2467754
03/17/18 03:06 PM
03/17/18 03:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The text in the FSM says to remove the front spring hanger in order to remove the pivot bolt, if the bolt head was toward the center of the car there would be no need to remove the hanger first.
Re: 69 Charger rear suspension front pivot bolt [Re: John_Kunkel] #2468954
03/20/18 08:26 AM
03/20/18 08:26 AM
NC
NC
John, are you saying the nut for the bolt is outboard?
Thanks!
Re: 69 Charger rear suspension front pivot bolt [Re: Sixt8Chrgr] #2469316
03/20/18 07:26 PM
03/20/18 07:26 PM
Mass
charge70 Online content
charge70  Online Content
Mass
No question about it,the nut goes out.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 69 Charger rear suspension front pivot bolt [Re: charge70] #2469575
03/21/18 08:48 AM
03/21/18 08:48 AM
NC
NC
I agree with you.
Re: 69 Charger rear suspension front pivot bolt [Re: Sixt8Chrgr] #2470303
03/22/18 12:04 PM
03/22/18 12:04 PM
moparx Offline
moparx  Offline
I agree with you.
x3 iagree my charger is that way from the factory, and i have owned it since 1970.
beer
Re: 69 Charger rear suspension front pivot bolt [Re: Sixt8Chrgr] #2471248
03/24/18 10:01 AM
03/24/18 10:01 AM
NC
NC
I have pictures of my Charger prior to disassembly and the nut was outboard. I am the third owner of my car and have known the car since I was 16. So know the car well. The reason I raised this question is because how the CSM has the diagram I posted and also the photographs in David Wise's Restoration and Judging guidelines showing the nut head outboard.
