Re: 69 Charger rear suspension front pivot bolt
[Re: Sixt8Chrgr]
#2465041
03/12/18 12:56 AM
03/12/18 12:56 AM
Posts: 356 Greenwood Lake, NY
fuelishnsilly
Greenwood Lake, NY
my originals on my car that my grand pop had since new was the nuts on the outboard side.
inherited a 69 roadrunner from my grand pop.
[Re: fuelishnsilly]
#2465136
03/12/18 11:16 AM
03/12/18 11:16 AM
Posts: 18,157 Mass
DAYCLONA
Mass
my originals on my car that my grand pop had since new was the nuts on the outboard side. Correct, that way if the nut falls off/rusts off the stud is trapped by the frame and cannot fall out of the front perch
[Re: DAYCLONA]
#2465436
03/12/18 09:41 PM
03/12/18 09:41 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: Sixt8Chrgr]
#2465512
03/12/18 10:59 PM
03/12/18 10:59 PM
Posts: 177 NC
Sixt8Chrgr
NC
Dayclona is that drawing for a B Body?
This is from my Service Manual. I still think the nut should be outboard but this drawing begs to differ?
[Re: Sixt8Chrgr]
#2465516
03/12/18 11:05 PM
03/12/18 11:05 PM
Posts: 177 NC
Sixt8Chrgr
NC
This is a little easier to see. This is from the 69 Service Manual. Seems like the bolt head is on the outboard side, but like I said before I restored my car I have pics of the nut being outboard. Any ideas what is correct?
[Re: Sixt8Chrgr]
#2467731
03/17/18 01:55 PM
03/17/18 01:55 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
On my 68 Charger, i know the bolts were installed from the inside because i can see the imprint of the bolt heads in the undercoating next to the bolt head on the adjacent rail. When they were putting the nuts on, the bolts must have pushed out and pressed into the inner frame rails making a perfect impression in the factory undercoating.
[Re: Sixt8Chrgr]
#2467754
03/17/18 03:06 PM
03/17/18 03:06 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The text in the FSM says to remove the front spring hanger in order to remove the pivot bolt, if the bolt head was toward the center of the car there would be no need to remove the hanger first.
[Re: John_Kunkel]
#2468954
03/20/18 08:26 AM
03/20/18 08:26 AM
Posts: 177 NC
Sixt8Chrgr
NC
John, are you saying the nut for the bolt is outboard? Thanks!
[Re: Sixt8Chrgr]
#2469316
03/20/18 07:26 PM
03/20/18 07:26 PM
Posts: 601 Mass
charge70
Mass
No question about it,the nut goes out.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: charge70]
#2469575
03/21/18 08:48 AM
03/21/18 08:48 AM
Posts: 177 NC
Sixt8Chrgr
NC
No question about it,the nut goes out. I agree with you.
[Re: Sixt8Chrgr]
#2470303
03/22/18 12:04 PM
03/22/18 12:04 PM
Posts: 19,342 north of coder
moparx
No question about it,the nut goes out. I agree with you. x3 my charger is that way from the factory, and i have owned it since 1970.
