Hellcat Blower #2462819
03/07/18 10:12 PM
03/07/18 10:12 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
So would a Hellcat blower support a 426 cube stroker?
Re: Hellcat Blower [Re: Dragula] #2462926
03/08/18 01:05 AM
03/08/18 01:05 AM
USA
hudsonhornet7x Offline
USA
I would say so, there are several stroker hellcat challengers out and about now. It would be one wicked ride for sure.
Re: Hellcat Blower [Re: Dragula] #2462945
03/08/18 01:53 AM
03/08/18 01:53 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Hmmmm I'm not sure. There is a bunch of cubic inch differance from a 6.2 And a 426......i would think if it would support a 426. They would not put a larger blower on the demon when it's the same size motor
What's a 6.2 377 or so. inches?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Hellcat Blower [Re: toplescuda] #2462989
03/08/18 08:36 AM
03/08/18 08:36 AM
Dragula Offline OP
Dragula  Offline OP
Correct on the cubes...the stock Hellcat blower is rated a 2.4L, the Dragpak uses a 2.9 Whipple, and there is a couple new blowers out there that are considerably bigger.
The Hellcat pushes the 377 cube engine to 10-11psi.....If I go with one of those and add 50 cubes, I would have to over drive it. Any idea how much to get back to 11psi?
Re: Hellcat Blower [Re: Dragula] #2463117
03/08/18 03:07 PM
03/08/18 03:07 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Thats what %9 bigger or so? Seems around %10 OD would allow similar levels of boost, I am sure it is not an exact thing but it should get you in the ball park.
Re: Hellcat Blower [Re: Dragula] #2463234
03/08/18 06:37 PM
03/08/18 06:37 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Plenty of overdriven Hellcat blowers as well. They seem to be able to deliver more psi when overdriven and not just create heat.
Re: Hellcat Blower [Re: Dragula] #2463587
03/09/18 08:04 AM
03/09/18 08:04 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
And a bunch of the overdrive blowers with fail bearings. Just buy a demon blower. Or. Kenne bell has a 4.2 blower...
1971 charger
Re: Hellcat Blower [Re: Dragula] #2464144
03/10/18 02:39 AM
03/10/18 02:39 AM
Australia
L4staero Offline
L4staero  Offline
Australia
They seem to have no problems keeping up with 426 cube motors. They ofcoarse need to be spun faster to produce the same boost. On a std HC a 10% OD lower will add about 3 psi. Going from a std 3.35" blower to a 2.65 one as well will give you around 18-19 psi. Change the motor to 426 cubes with head work and a different cam and the same pullies that gave 19 psi is now down around 11-12 psi.
Spinning them faster doesnt seem to be a catalyst for bearing failures
Re: Hellcat Blower [Re: Dragula] #2464689
03/11/18 12:57 PM
03/11/18 12:57 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
they fail no matter the rpm,
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Hellcat Blower [Re: Dragula] #2464848
03/11/18 06:26 PM
03/11/18 06:26 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I thought they've updated the blowers and fixed the bearing problems?
Re: Hellcat Blower [Re: Dragula] #2464943
03/11/18 09:40 PM
03/11/18 09:40 PM
USA
USA
Yes, there are certain part numbers on the blowers that are " updated and fine"
Re: Hellcat Blower [Re: hudsonhornet7x] #2465094
03/12/18 09:20 AM
03/12/18 09:20 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Originally Posted By hudsonhornet7x
" updated and fine"
my neighbor and his 2017 Hellcat will disagree.
Re: Hellcat Blower [Re: ric3xrt] #2465179
03/12/18 01:11 PM
03/12/18 01:11 PM
USA
USA
" updated and fine"
I can understand that. From what I have read there are several batches with noisy bearings. Sucks to be sure. Has your neighbor had his blower replaced?
Re: Hellcat Blower [Re: Dragula] #2465195
03/12/18 02:01 PM
03/12/18 02:01 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Dealer replaced it in Nov, and when it started again in early Feb that's when we changed it out for a new 4.5l Whipple,
We have salesman here at work that has a 2015 with 45k on it supercharger was replaced at 11k and it's been good since. Now both of these guys will tell you FCA bent over backwards to keep them satisfied.
Re: Hellcat Blower [Re: Dragula] #2465353
03/12/18 07:05 PM
03/12/18 07:05 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Guess when I see a cheap one for sale on ebay, I know why.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Hellcat Blower [Re: Dragula] #2465586
03/13/18 12:55 AM
03/13/18 12:55 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I saw mention on Hellcat.org of a guy who offers rebuild services for these blowers with a new problem solver bearing that’s supposed to fix this. Of course it’s a proprietary bearing that he doesn’t sell to anyone
Re: Hellcat Blower [Re: Dragula] #2466092
03/13/18 11:07 PM
03/13/18 11:07 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Yes. For 1800.00 bucks
1971 charger
