#2462819 - 03/07/18 07:12 PM Hellcat Blower
Dragula Offline
Loc: Taxes R-US, NY
So would a Hellcat blower support a 426 cube stroker?
'71 Duster Pump Gas 512LD 2013 Mod Gas Winner GRS
https://www.youtube.com/watch?v=Z_XTmRBuvWs (6.19)
https://www.youtube.com/watch?v=gQZGfDBPROM (9.70 at 138.5mph)
'70 Cuda, Plan C....605 Hemi
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.31)
#2462926 - 03/07/18 10:05 PM Re: Hellcat Blower [Re: Dragula]
hudsonhornet7x Offline
Loc: Plumer, Pa
I would say so, there are several stroker hellcat challengers out and about now. It would be one wicked ride for sure.
XP29H8B198192
#2462945 - 03/07/18 10:53 PM Re: Hellcat Blower [Re: Dragula]
toplescuda Offline
I Whine
Loc: poplar bluff mo.
Hmmmm I'm not sure. There is a bunch of cubic inch differance from a 6.2 And a 426......i would think if it would support a 426. They would not put a larger blower on the demon when it's the same size motor
What's a 6.2 377 or so. inches?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
#2462989 - 03/08/18 05:36 AM Re: Hellcat Blower [Re: toplescuda]
Dragula Offline
Loc: Taxes R-US, NY
Correct on the cubes...the stock Hellcat blower is rated a 2.4L, the Dragpak uses a 2.9 Whipple, and there is a couple new blowers out there that are considerably bigger.
The Hellcat pushes the 377 cube engine to 10-11psi.....If I go with one of those and add 50 cubes, I would have to over drive it. Any idea how much to get back to 11psi?
Edited by Dragula (03/08/18 05:42 AM)
#2463117 - 03/08/18 12:07 PM Re: Hellcat Blower [Re: Dragula]
HotRodDave Online   content
Loc: Kalispell Mt.
Thats what %9 bigger or so? Seems around %10 OD would allow similar levels of boost, I am sure it is not an exact thing but it should get you in the ball park.
68 cuda 360 notchback SOLD
1996 Ram 2500 5.9 eddy intake EQ heads, mild cam upgrade great tow rig!
#2463234 - 03/08/18 03:37 PM Re: Hellcat Blower [Re: Dragula]
WO23Coronet Offline
Loc: Canada
Plenty of overdriven Hellcat blowers as well. They seem to be able to deliver more psi when overdriven and not just create heat.
#2463587 - 03/09/18 05:04 AM Re: Hellcat Blower [Re: Dragula]
toplescuda Offline
I Whine
And a bunch of the overdrive blowers with fail bearings. Just buy a demon blower. Or. Kenne bell has a 4.2 blower...
1971 charger
#2464144 - 03/09/18 11:39 PM Re: Hellcat Blower [Re: Dragula]
L4staero Offline
Loc: Australia
They seem to have no problems keeping up with 426 cube motors. They ofcoarse need to be spun faster to produce the same boost. On a std HC a 10% OD lower will add about 3 psi. Going from a std 3.35" blower to a 2.65 one as well will give you around 18-19 psi. Change the motor to 426 cubes with head work and a different cam and the same pullies that gave 19 psi is now down around 11-12 psi.
Spinning them faster doesnt seem to be a catalyst for bearing failures
Edited by L4staero (03/09/18 11:40 PM)
#2464689 - 03/11/18 10:57 AM Re: Hellcat Blower [Re: Dragula]
ric3xrt Offline
Loc: Trumbauersville PA
they fail no matter the rpm,
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
#2464848 - 03/11/18 04:26 PM Re: Hellcat Blower [Re: Dragula]
WO23Coronet Offline
Loc: Canada
I thought they've updated the blowers and fixed the bearing problems?
#2464943 - 03/11/18 07:40 PM Re: Hellcat Blower [Re: Dragula]
Loc: Plumer, Pa
Yes, there are certain part numbers on the blowers that are " updated and fine"
XP29H8B198192
#2465094 - 03/12/18 07:20 AM Re: Hellcat Blower [Re: hudsonhornet7x]
ric3xrt Offline
Originally Posted By hudsonhornet7x
" updated and fine"
my neighbor and his 2017 Hellcat will disagree.
#2465179 - 03/12/18 11:11 AM Re: Hellcat Blower [Re: ric3xrt]
Loc: Plumer, Pa
" updated and fine"
I can understand that. From what I have read there are several batches with noisy bearings. Sucks to be sure. Has your neighbor had his blower replaced?
XP29H8B198192
#2465195 - 03/12/18 12:01 PM Re: Hellcat Blower [Re: Dragula]
ric3xrt Offline
Dealer replaced it in Nov, and when it started again in early Feb that's when we changed it out for a new 4.5l Whipple,
We have salesman here at work that has a 2015 with 45k on it supercharger was replaced at 11k and it's been good since. Now both of these guys will tell you FCA bent over backwards to keep them satisfied.
#2465353 - 03/12/18 05:05 PM Re: Hellcat Blower [Re: Dragula]
Silver70 Offline
Loc: Rust Belt, SW PA
Guess when I see a cheap one for sale on ebay, I know why.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
99 Trans Am, 66 GTO, 06 Magnum RT AWD
#2465586 - 03/12/18 10:55 PM Re: Hellcat Blower [Re: Dragula]
WO23Coronet Offline
Loc: Canada
I saw mention on Hellcat.org of a guy who offers rebuild services for these blowers with a new problem solver bearing that’s supposed to fix this. Of course it’s a proprietary bearing that he doesn’t sell to anyone
#2466092 - 03/13/18 09:07 PM Re: Hellcat Blower [Re: Dragula]
toplescuda Offline
I Whine
Yes. For 1800.00 bucks
1971 charger
25,485 Registered Members
192,932 Topics
Powerglide adapters, what y’all like?
by mopar97
09/19/18 12:14 PM
New Products from Mancini Racing
by Mancini Racing
09/19/18 11:21 AM
Classic Industries’ ’68-69 Charger Hood Turn Signal Indicat.
by Rustymuscle
09/19/18 10:39 AM
Anyone try these exhaust cut-outs?
by 1970RT
09/19/18 10:33 AM
