Re: never had this happen before..
[Re: 734x4PW]
#246263
03/07/09 10:39 PM
03/07/09 10:39 PM
Posts: 4,588 St. John's Newfoundland
440newport
Yea, you have rust issues up there, don't ya! Good thing you weren't in a critical situation. That might have ended up in a tragedy. Events like these give us the time to do things we need to do, don't they?
Mark
Yeah, like I said it could have been much worse. I had brake lines bust on me on other cars before, though always on the rear for some reason? But I would usually still have some brake power...this time I had nothing, coasted right on through the stop sign.
[Re: 440newport]
#246265
03/07/09 11:33 PM
03/07/09 11:33 PM
Posts: 1,806 Newfoundland Canada
Mopar1
Newfoundland Canada
You might want to check your front lines too. You still should've had front braking power even though the rear failed.
[Re: mopargem]
#246268
03/08/09 12:19 AM
03/08/09 12:19 AM
440newport
Maybe it's time to CRUSH IT!
No way, it's a good solid truck otherwise...good chassis, floors etc...the inner rockers and rear wheel wells are a little soft but no big deal.
[Re: 62maxwgn]
#246270
03/08/09 12:43 PM
03/08/09 12:43 PM
440newport
You may want to watch things a little closer,that didn't happen overnight.
I know what you mean but when was the last time you inspected your backing plates? Like I said, in the first post I knew it was a bit rusty and I knew I should have replaced it but I never got around to it until it broke.
