never had this happen before.. #246260
03/07/09 10:30 PM
03/07/09 10:30 PM
St. John's Newfoundland
440newport Offline OP
The other day I was on my way to work in my '90 W-150. Coming to a stop sign I hit the brakes and heard a banging noise followed by losing all pedal pressure. Luckily there was no traffic and I wasn't going very fast anyways so I was able to come to stop by gearing down and pumping the pedal a bunch.
At first I thought the noise was up front, but I looked under the back and noticed one of the E-brake cables hanging down along with a piece of brake line. I looked at the backing plate on the driver side and then I see the wheel cylinder is on the bottom!
Anyways, I get it back home (using the E-brake still working on one wheel which worked surprisingly well) I get the drum off and see the backing plate looks like this...the inner part where it bolts to the housing was pretty rusty but I never thought it would rip off. I actually saw a few small holes in it back when I bought the truck, and I knew I should have replaced it then but I kept putting it off because of the pain of having to pull the axle (9.25), the stinky gear oil etc...Guess I should have done it sooner, and it could have been a lot worse.
Re: never had this happen before.. [Re: 440newport] #246261
03/07/09 10:33 PM
03/07/09 10:33 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
i've seen where the drum itself breaks...the face that bolts to the axle breaks from the drum surface that touches the brake shoe lining...
Re: never had this happen before.. [Re: 440newport] #246262
03/07/09 10:34 PM
03/07/09 10:34 PM
Joplin, MO
734x4PW Offline
734x4PW  Offline
Joplin, MO
Yea, you have rust issues up there, don't ya! Good thing you weren't in a critical situation. That might have ended up in a tragedy. Events like these give us the time to do things we need to do, don't they?
Mark
Re: never had this happen before.. [Re: 734x4PW] #246263
03/07/09 10:39 PM
03/07/09 10:39 PM
Mark
Yeah, like I said it could have been much worse. I had brake lines bust on me on other cars before, though always on the rear for some reason? But I would usually still have some brake power...this time I had nothing, coasted right on through the stop sign.
Re: never had this happen before.. [Re: 440newport] #246264
03/07/09 11:31 PM
03/07/09 11:31 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Good old eastern rot. Gives me nightmares just remembering working on those cars for a living.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: never had this happen before.. [Re: 440newport] #246265
03/07/09 11:33 PM
03/07/09 11:33 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
You might want to check your front lines too. You still should've had front braking power even though the rear failed.
Re: never had this happen before.. [Re: Mopar1] #246266
03/08/09 12:10 AM
03/08/09 12:10 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Maybe it's time to CRUSH IT!
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: never had this happen before.. [Re: 440newport] #246267
03/08/09 12:18 AM
03/08/09 12:18 AM
florida
E
edmopar440 Offline
edmopar440  Offline
E
florida
HAD SAME THING HAPPEN ON MY 89 DAKOTA WITH 300,000 MILES GOT NEW ONES FROM MOPAR AND BACK ON THE ROAD..ED
Re: never had this happen before.. [Re: mopargem] #246268
03/08/09 12:19 AM
03/08/09 12:19 AM
No way, it's a good solid truck otherwise...good chassis, floors etc...the inner rockers and rear wheel wells are a little soft but no big deal.
Re: never had this happen before.. [Re: 440newport] #246269
03/08/09 10:15 AM
03/08/09 10:15 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You may want to watch things a little closer,that didn't happen overnight.
Re: never had this happen before.. [Re: 62maxwgn] #246270
03/08/09 12:43 PM
03/08/09 12:43 PM
I know what you mean but when was the last time you inspected your backing plates? Like I said, in the first post I knew it was a bit rusty and I knew I should have replaced it but I never got around to it until it broke.
