What is the name of this sway bar bracket? #2462596
03/07/18 03:15 PM
03/07/18 03:15 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hi all,
I'm installing a sway bar on my '71 Satellite, and need to know the name of a part. I am unable to find it in my 1971 Parts Manual. It's the black strap that the gold bracket is attached to in this photo:
https://photos.app.goo.gl/IeI7kEq24vILxaXp2
I'd appreciate the name, and a source if anyone knows. Thanks.
Roger
Re: What is the name of this sway bar bracket? [Re: Fab64] #2462603
03/07/18 03:28 PM
03/07/18 03:28 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
I doubt if it's called anything other than "mount bracket" to the crossmember.
That's what i have always referred them as, for decades, when i came across sway bars to clean up, then resell.
To my knowledge, i don't think anyone repops the factory style brackets.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: What is the name of this sway bar bracket? [Re: Fab64] #2462636
03/07/18 04:20 PM
03/07/18 04:20 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
that just looks like the sway bar bushings/bracket that most of the poly company's sell.
http://energysuspension.com/products/Sway-Bar-End-Link-Bushings.html
Re: What is the name of this sway bar bracket? [Re: mikemee1331] #2462716
03/07/18 06:45 PM
03/07/18 06:45 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
No, those are the bushing brackets, which are easily available. I need the black brackets that span the gap in the K-frame, and which the bushing brackets mount to (the long black brackets in this pic):
https://photos.app.goo.gl/Ds8GBRQaGlrsIDdX2
I found that Hellwig makes a mounting kit that contains these brackets, but unfortunately they don't sell directly to the public. It's hard to believe these things aren't available by themselves.
Re: What is the name of this sway bar bracket? [Re: Fab64] #2462823
03/07/18 10:18 PM
03/07/18 10:18 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
According to the Year One web site, they have them, but there is no picture to confirm. Might be in catalog. For info, they are the same a E body. I have see new one's other places, but can't remember where.
Re: What is the name of this sway bar bracket? [Re: 71birdJ68] #2462835
03/07/18 10:30 PM
03/07/18 10:30 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
You mean those flat pieces with the bolt holes?
Why not just make them yourself?
I have mechanical Aptitude.
I can screw up anything.
Re: What is the name of this sway bar bracket? [Re: 71birdJ68] #2462845
03/07/18 10:46 PM
03/07/18 10:46 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I agree with him, you could make them, unless you are wanting factory look, cause they were stamped out with two lips on them. The lips are on the bottom, so you wouldn't see it unless you got under the car to look for it.
Re: What is the name of this sway bar bracket? [Re: 71birdJ68] #2462933
03/08/18 01:22 AM
03/08/18 01:22 AM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Thanks, guys. I'm not as concerned about looks as I am with their strength & fit, plus spending half a day making them. If I can find them at a reasonable price, I'd rather save the time. I have a lead on Firm Feel, and I'll also check out Year One. Thanks again!
Re: What is the name of this sway bar bracket? [Re: Fab64] #2463111
03/08/18 02:58 PM
03/08/18 02:58 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Updated info:
- The Year One kit SK702 consists only of the nuts and bolts required to mount the bracket to the K-frame. It does not include the brackets themselves.
- Firm Feel manufactures and sells the brackets, nicely machined out of aluminum, powder coated black, $135/pair
