What is the name of this sway bar bracket?
#2462596
03/07/18 03:15 PM
03/07/18 03:15 PM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
Hi all, I'm installing a sway bar on my '71 Satellite, and need to know the name of a part. I am unable to find it in my 1971 Parts Manual. It's the black strap that the gold bracket is attached to in this photo: https://photos.app.goo.gl/IeI7kEq24vILxaXp2I'd appreciate the name, and a source if anyone knows. Thanks. Roger
Re: What is the name of this sway bar bracket?
[Re: Fab64]
#2462603
03/07/18 03:28 PM
03/07/18 03:28 PM
Posts: 5,354 Rancho Cordova, California (Sa...
hemi71x
I doubt if it's called anything other than "mount bracket" to the crossmember. That's what i have always referred them as, for decades, when i came across sway bars to clean up, then resell. To my knowledge, i don't think anyone repops the factory style brackets.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: mikemee1331]
#2462716
03/07/18 06:45 PM
03/07/18 06:45 PM
Fab64
So Cal, USA
No, those are the bushing brackets, which are easily available. I need the black brackets that span the gap in the K-frame, and which the bushing brackets mount to (the long black brackets in this pic): https://photos.app.goo.gl/Ds8GBRQaGlrsIDdX2I found that Hellwig makes a mounting kit that contains these brackets, but unfortunately they don't sell directly to the public. It's hard to believe these things aren't available by themselves.
[Re: 71birdJ68]
#2462835
03/07/18 10:30 PM
03/07/18 10:30 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
You mean those flat pieces with the bolt holes? Why not just make them yourself?
I have mechanical Aptitude. I can screw up anything.
