#2456389 - 02/23/18 08:35 PM Hellcat Crate Swap.....
Dragula Offline
Loc: Taxes R-US, NY
Who's done one, how are you guys mounting yours?
I got a tubular k-member, so I am curious what the options are.
'71 Duster Pump Gas 512LD 2013 Mod Gas Winner GRS
https://www.youtube.com/watch?v=Z_XTmRBuvWs (6.19)
https://www.youtube.com/watch?v=gQZGfDBPROM (9.70 at 138.5mph)
'70 Cuda, Plan C....605 Hemi
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.31)
#2457008 - 02/24/18 08:11 PM Re: Hellcat Crate Swap..... [Re: Dragula]
Dragula Offline
Loc: Taxes R-US, NY
You know, if you guys make me figure everything out myself...And I go thru with this, I am not telling how I did it...
#2457048 - 02/24/18 08:59 PM Re: Hellcat Crate Swap..... [Re: Dragula]
mymcodebee Offline
Loc: Far Northeast.
I just ordered a transformer suspension with mounts for the charger were doing.
#2457057 - 02/24/18 09:09 PM Re: Hellcat Crate Swap..... [Re: mymcodebee]
Dragula Offline
Loc: Taxes R-US, NY
Well I have the MF tubular and it has no motor mounts. Always used a motor plate...
Did you order yours with motor mounts?
#2457087 - 02/24/18 09:52 PM Re: Hellcat Crate Swap..... [Re: Dragula]
biff426 Offline
Loc: Delaware
Pretty sure the motor plate AEI makes would work on the hell cat you would have to ask but that would be the way I would do it. Not sure how it impacts the belt routing.
Edited by biff426 (02/24/18 09:52 PM)
#2457644 - 02/25/18 09:19 PM Re: Hellcat Crate Swap..... [Re: Dragula]
Bad340fish Offline
Loc: Tulsa OK
I would imagine a motor plate would not be any fun with the hellcat motor. Lots to remove to get to it and I am sure it would impact accessory spacing and cause hell with the belt. I would look at fabricating some motor mounts on your K-frame.
68 Barracuda Formula S 340
#2457694 - 02/25/18 10:35 PM Re: Hellcat Crate Swap..... [Re: Dragula]
B5 Classic Offline
Loc: Northern California
I am using an AlterKtion front suspension to mount my Hellcrate into my '69 Cuda. All fabbing and fitting was done with my originally planned 6.1 based BES 392 stroker. Just got side tracked when they came out with the Hellcrate. The only problem I anticipate is possible interference between the firewall and the cast aluminum, cooling water manifold bolted to the back of the blower case. Probably won't have time to fit the Hellcrate until May. Is your car an A body? Would love to know what you've found if you set the Hellcrate in the engine bay.
#2457761 - 02/26/18 05:49 AM Re: Hellcat Crate Swap..... [Re: B5 Classic]
Dragula Offline
Loc: Taxes R-US, NY
My first thought was to put it in my 70 Cuda...since my 605 Hemi is hemorrhaging oil pressure...I am looking for a new power plant. Tired of doing the wedge thing, and tired of Gen2 Hemi's not being reliable.....The car will handle the engine, but can only use a plate to mount it. Never had engine mounts with the tubular k-frame...
#2457771 - 02/26/18 07:10 AM Re: Hellcat Crate Swap..... [Re: Dragula]
biff426 Offline
Loc: Delaware
I am assuming a car with tubular K frame = no accessories other then water pump and Alt I would think the plate is doable I would call AEI you will probably need to fab a tensioner program and I believe the stock water pump goes away but I would think you could drive the blower and alt with the same belt and use an electric water pump just fab a tensioner
#2457810 - 02/26/18 09:25 AM Re: Hellcat Crate Swap..... [Re: Dragula]
RTSE4ME Offline
Loc: MD
Looks like the supercharger drive might be the hard part?
Accessories wouldn't be that bad. I would think fabbing engine mounts would be easier.
#2458108 - 02/26/18 07:04 PM Re: Hellcat Crate Swap..... [Re: Dragula]
AeroMonte Offline
Loc: S.E. Missouri
This tubular k frame was in our Barracuda when we bought it. I made the mounts out of cardboard first, set the hellcat into the car where it needed to be, made the plates from 1/4 inch plate and tack welded in place. Bought motor mounts from RPM. It fits great in the car even with the coolant crossover.
#2458297 - 02/27/18 09:02 AM Re: Hellcat Crate Swap..... [Re: Dragula]
Quickrunner Offline
Loc: Indianapolis In. usa
Don't think you will be able to combine the AEI plate with any of the drive system on the hellcrate. I have not seen any blower drive systems that wont have to be custom made with a motor plate/gen3 setup. I'd add mounts like AeroMonte did if you already have the hellcrate.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
2004 Jeep Liberty
09 Challenger R/T 6spd
Missin' my 9 second 70 runner!
#2459024 - 02/28/18 04:17 PM Re: Hellcat Crate Swap..... [Re: Dragula]
72Swinger Offline
Loc: Nebraska
Make mounts and leave engine stock would be way less stressful IMO.
Mopar to the bone!!!
#2459266 - 03/01/18 03:44 AM Re: Hellcat Crate Swap..... [Re: Dragula]
aus370 Offline
Loc: Australia
That's my thoughts as well , beef up the tubular k frame if necessary to take mounts.
Edited by aus370 (03/01/18 05:08 AM)
Stock 6.1 Hemi . 11.657 @ 113.54 , 3588 lbs.
#2459299 - 03/01/18 07:51 AM Re: Hellcat Crate Swap..... [Re: Dragula]
Just-a-dart Online   content
Loc: Glendora Ca.
You might want to look at the Comp engineering mount with a mid plate. www.summitracing.com/int/parts/cee-4012
"Just a Bracket car dressed up like a streetcar"
#2459320 - 03/01/18 08:47 AM Re: Hellcat Crate Swap..... [Re: Dragula]
ric3xrt Offline
Loc: Trumbauersville PA
my .02 worth , I'd get an AEI plate ,ATI Hellcat damper put a cog belt pulley on the ATI damper(it can be done it has been done) Cog belt the blower, electric water pump and separate belt for the alt.
Your Cuda doesn't strike me as a air-conditioner queen
Edited by ric3xrt (03/01/18 08:50 AM)
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
#2460962 - 03/04/18 01:30 PM Re: Hellcat Crate Swap..... [Re: ric3xrt]
Dragula Offline
Loc: Taxes R-US, NY
So a little more digging, and I found this comparison of timing covers...Looks like they are different and would require a unique engine plate...
Good write up in HRM
http://www.hotrod.com/articles/we-take-a-hard-look-at-dodges-paradigm-shifting-707hp-hellcat-hemi/
dodge-370ci-v-8-supercharged-hellcat-hemi-engine-front-cover-392-apache-comparison.jpg
Edited by Dragula (03/04/18 01:58 PM)
#2461559 - 03/05/18 02:06 PM Re: Hellcat Crate Swap..... [Re: Dragula]
Quickrunner Offline
My AEI motor plate uses a modified truck timing cover.
2004 Jeep Liberty
#2461742 - 03/05/18 07:56 PM Re: Hellcat Crate Swap..... [Re: Quickrunner]
onig Offline
Loc: Canada
Any pics of this?
69 Dart, The BB is now gone, Soon to be Gen 3 Hemi...
#2462119 - 03/06/18 03:28 PM Re: Hellcat Crate Swap..... [Re: onig]
Quickrunner Offline
Not a good pic of the cover, think AEI has a pic on their site.
2004 Jeep Liberty
25,631 Registered Members
195,576 Topics
77 Ramcharger w/plow Madion, WI Craigslist
by Rhinodart
11 minutes 13 seconds ago
Weird inconsistant studder in the engine
by Andrewh
Today at 10:12 AM
Original Mr. Norm’s T-Shirt
by floyd
Today at 09:58 AM
AAA roadside replacement battery?
by magnum440d100
Today at 09:27 AM
