Hellcat Crate Swap..... #2456389
02/23/18 11:35 PM
02/23/18 11:35 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Who's done one, how are you guys mounting yours?
I got a tubular k-member, so I am curious what the options are.
Re: Hellcat Crate Swap..... [Re: Dragula] #2457008
02/24/18 11:11 PM
02/24/18 11:11 PM
Dragula Offline OP
Dragula  Offline OP
You know, if you guys make me figure everything out myself...And I go thru with this, I am not telling how I did it...
Re: Hellcat Crate Swap..... [Re: Dragula] #2457048
02/24/18 11:59 PM
02/24/18 11:59 PM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
I just ordered a transformer suspension with mounts for the charger were doing.
Re: Hellcat Crate Swap..... [Re: mymcodebee] #2457057
02/25/18 12:09 AM
02/25/18 12:09 AM
Dragula Offline OP
Dragula  Offline OP
Well I have the MF tubular and it has no motor mounts. Always used a motor plate...
Did you order yours with motor mounts?
Re: Hellcat Crate Swap..... [Re: Dragula] #2457087
02/25/18 12:52 AM
02/25/18 12:52 AM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
Pretty sure the motor plate AEI makes would work on the hell cat you would have to ask but that would be the way I would do it. Not sure how it impacts the belt routing.
Re: Hellcat Crate Swap..... [Re: Dragula] #2457644
02/26/18 12:19 AM
02/26/18 12:19 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I would imagine a motor plate would not be any fun with the hellcat motor. Lots to remove to get to it and I am sure it would impact accessory spacing and cause hell with the belt. I would look at fabricating some motor mounts on your K-frame.
68 Barracuda Formula S 340
Re: Hellcat Crate Swap..... [Re: Dragula] #2457694
02/26/18 01:35 AM
02/26/18 01:35 AM
Northern California
B5 Classic Offline
B5 Classic  Offline
Northern California
I am using an AlterKtion front suspension to mount my Hellcrate into my '69 Cuda. All fabbing and fitting was done with my originally planned 6.1 based BES 392 stroker. Just got side tracked when they came out with the Hellcrate. The only problem I anticipate is possible interference between the firewall and the cast aluminum, cooling water manifold bolted to the back of the blower case. Probably won't have time to fit the Hellcrate until May. Is your car an A body? Would love to know what you've found if you set the Hellcrate in the engine bay.
Re: Hellcat Crate Swap..... [Re: B5 Classic] #2457761
02/26/18 08:49 AM
02/26/18 08:49 AM
Dragula Offline OP
Dragula  Offline OP
My first thought was to put it in my 70 Cuda...since my 605 Hemi is hemorrhaging oil pressure...I am looking for a new power plant. Tired of doing the wedge thing, and tired of Gen2 Hemi's not being reliable.....The car will handle the engine, but can only use a plate to mount it. Never had engine mounts with the tubular k-frame...
Re: Hellcat Crate Swap..... [Re: Dragula] #2457771
02/26/18 10:10 AM
02/26/18 10:10 AM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
I am assuming a car with tubular K frame = no accessories other then water pump and Alt I would think the plate is doable I would call AEI you will probably need to fab a tensioner program and I believe the stock water pump goes away but I would think you could drive the blower and alt with the same belt and use an electric water pump just fab a tensioner
Re: Hellcat Crate Swap..... [Re: Dragula] #2457810
02/26/18 12:25 PM
02/26/18 12:25 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Looks like the supercharger drive might be the hard part?
Accessories wouldn't be that bad. I would think fabbing engine mounts would be easier.
Re: Hellcat Crate Swap..... [Re: Dragula] #2458108
02/26/18 10:04 PM
02/26/18 10:04 PM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
This tubular k frame was in our Barracuda when we bought it. I made the mounts out of cardboard first, set the hellcat into the car where it needed to be, made the plates from 1/4 inch plate and tack welded in place. Bought motor mounts from RPM. It fits great in the car even with the coolant crossover.
Re: Hellcat Crate Swap..... [Re: Dragula] #2458297
02/27/18 12:02 PM
02/27/18 12:02 PM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
Don't think you will be able to combine the AEI plate with any of the drive system on the hellcrate. I have not seen any blower drive systems that wont have to be custom made with a motor plate/gen3 setup. I'd add mounts like AeroMonte did if you already have the hellcrate.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Hellcat Crate Swap..... [Re: Dragula] #2459024
02/28/18 07:17 PM
02/28/18 07:17 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Make mounts and leave engine stock would be way less stressful IMO.
Mopar to the bone!!!
Re: Hellcat Crate Swap..... [Re: Dragula] #2459266
03/01/18 06:44 AM
03/01/18 06:44 AM
Australia
aus370 Offline
aus370  Offline
Australia
That's my thoughts as well , beef up the tubular k frame if necessary to take mounts.
Re: Hellcat Crate Swap..... [Re: Dragula] #2459299
03/01/18 10:51 AM
03/01/18 10:51 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
You might want to look at the Comp engineering mount with a mid plate. www.summitracing.com/int/parts/cee-4012
"Just a Bracket car dressed up like a streetcar"
Re: Hellcat Crate Swap..... [Re: Dragula] #2459320
03/01/18 11:47 AM
03/01/18 11:47 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
my .02 worth , I'd get an AEI plate ,ATI Hellcat damper put a cog belt pulley on the ATI damper(it can be done it has been done) Cog belt the blower, electric water pump and separate belt for the alt.
Your Cuda doesn't strike me as a air-conditioner queen
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Hellcat Crate Swap..... [Re: ric3xrt] #2460962
03/04/18 04:30 PM
03/04/18 04:30 PM
Dragula Offline OP
Dragula  Offline OP
So a little more digging, and I found this comparison of timing covers...Looks like they are different and would require a unique engine plate...
Good write up in HRM
http://www.hotrod.com/articles/we-take-a-hard-look-at-dodges-paradigm-shifting-707hp-hellcat-hemi/
dodge-370ci-v-8-supercharged-hellcat-hemi-engine-front-cover-392-apache-comparison.jpg
Re: Hellcat Crate Swap..... [Re: Dragula] #2461559
03/05/18 05:06 PM
03/05/18 05:06 PM
Quickrunner Offline
Quickrunner  Offline
My AEI motor plate uses a modified truck timing cover.
Re: Hellcat Crate Swap..... [Re: Quickrunner] #2461742
03/05/18 10:56 PM
03/05/18 10:56 PM
Canada
onig Offline
onig  Offline
Canada
Any pics of this?
69 Dart
Re: Hellcat Crate Swap..... [Re: onig] #2462119
03/06/18 06:28 PM
03/06/18 06:28 PM
Quickrunner Offline
Quickrunner  Offline
Not a good pic of the cover, think AEI has a pic on their site.
