Re: Hellcat Crate Swap.....
[Re: Dragula]
#2457087
02/25/18 12:52 AM
02/25/18 12:52 AM
Posts: 935 Deland, Florida
biff426
Deland, Florida
Pretty sure the motor plate AEI makes would work on the hell cat you would have to ask but that would be the way I would do it. Not sure how it impacts the belt routing.
[Re: Dragula]
#2457644
02/26/18 12:19 AM
02/26/18 12:19 AM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
I would imagine a motor plate would not be any fun with the hellcat motor. Lots to remove to get to it and I am sure it would impact accessory spacing and cause hell with the belt. I would look at fabricating some motor mounts on your K-frame.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: Dragula]
#2458297
02/27/18 12:02 PM
02/27/18 12:02 PM
Posts: 625 Indianapolis In. usa
Quickrunner
Don't think you will be able to combine the AEI plate with any of the drive system on the hellcrate. I have not seen any blower drive systems that wont have to be custom made with a motor plate/gen3 setup. I'd add mounts like AeroMonte did if you already have the hellcrate.
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
[Re: Dragula]
#2459024
02/28/18 07:17 PM
02/28/18 07:17 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Make mounts and leave engine stock would be way less stressful IMO.
Mopar to the bone!!!
[Re: Dragula]
#2459266
03/01/18 06:44 AM
03/01/18 06:44 AM
Posts: 80 Australia
aus370
Australia
That's my thoughts as well , beef up the tubular k frame if necessary to take mounts.
[Re: Dragula]
#2459320
03/01/18 11:47 AM
03/01/18 11:47 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
my .02 worth , I'd get an AEI plate ,ATI Hellcat damper put a cog belt pulley on the ATI damper(it can be done it has been done) Cog belt the blower, electric water pump and separate belt for the alt. Your Cuda doesn't strike me as a air-conditioner queen
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: Dragula]
#2461559
03/05/18 05:06 PM
03/05/18 05:06 PM
Quickrunner
My AEI motor plate uses a modified truck timing cover.
[Re: Quickrunner]
#2461742
03/05/18 10:56 PM
03/05/18 10:56 PM
Posts: 361 Canada
onig
Canada
My AEI motor plate uses a modified truck timing cover. Any pics of this?
69 Dart
[Re: onig]
#2462119
03/06/18 06:28 PM
03/06/18 06:28 PM
Quickrunner
Not a good pic of the cover, think AEI has a pic on their site.
