Reusing copper head gaskets #246158
03/07/09 08:14 PM
03/07/09 08:14 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Can the head gaskets be used again?
This is a 400 block , 4.435 bore (.095" over) , heads are O ringed (B1s), CR around 13:1 , is it a simple matter of cleaning the old silicone off & applying some around water ways? , is it necessary to anneal the gaskets?
TIA.
Re: Reusing copper head gaskets [Re: 602heavy] #246159
03/07/09 08:25 PM
03/07/09 08:25 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i used brake cleaner to get the silicone off and 000 steel wool or scotchbrite to scrub it.lacquer thinner final clean and reuse on same head it came from.
how much change in color in the copper?
Re: Reusing copper head gaskets [Re: blownzoom440] #246160
03/07/09 08:54 PM
03/07/09 08:54 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
No change in colour whatsoever , don't think the motor has been run , although the gaskets were torqued down.
Just a bit worried regards siliconing the gaskets , i take it a very thin bead will be ok?
Re: Reusing copper head gaskets [Re: 602heavy] #246161
03/07/09 09:03 PM
03/07/09 09:03 PM
ELYRIA,OH
ELYRIA,OH
not like my over thick spread. that was a 1st time doing it.i do as thin as i can almost wiping it off thin.
edit: if no heat has been put in the gasket there is no need to worry about reusing it.just clean it.
Re: Reusing copper head gaskets [Re: blownzoom440] #246162
03/08/09 01:43 AM
03/08/09 01:43 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
before i stepped into cometics i ran copper. when we reused & cleaned the gasket up nice we would re-anneal the copper by heating it up red hot & dunking into a water trough. this made the copper sooo soft again & with the usual copper coat & silicon we were good to go again.
Re: Reusing copper head gaskets [Re: rebel] #246163
03/08/09 02:10 AM
03/08/09 02:10 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
HOW do you heat-it red-hot ?
What is te best place to buy these? .... and are they the best deal around now as far as head gaskets(cost & performance) - period?
Re: Reusing copper head gaskets [Re: dOc !] #246164
03/08/09 02:45 AM
03/08/09 02:45 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You heat it with a rosebud (keep it moving) they seal compression well but are known for weeping coolant & oil...Which is why the coating of Copper coat sealer... Been around since at least the fifties...
Re: Reusing copper head gaskets [Re: dOc !] #246165
03/08/09 05:09 AM
03/08/09 05:09 AM
ELYRIA,OH
ELYRIA,OH
i put mine in the oven at 300* untel thay turned blue,air cooled,scotchbrite and then lacquer thinner... there was a comment that as long as the gasket bends easy you dont need to aneal it. easy depends on the thickness i guess.
Re: Reusing copper head gaskets [Re: blownzoom440] #246166
03/08/09 05:49 AM
03/08/09 05:49 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
THX guys .... now having to put-together a couple of alum headed motors .. THESE gaskets seem to be the ticket.
I can deal with that oven-prep .. but a rose bud ? .. !!
Where do you get these, how do they work on a daily driver(and maybe even a motorhome motor) ?
Are there any shelf-sizes and stock sizes ? ... or are they made-to-order ? ... to each bore size and thickness ?
Got a list of places that have them ? ... THX
Re: Reusing copper head gaskets [Re: dOc !] #246167
03/08/09 06:03 AM
03/08/09 06:03 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Re: Reusing copper head gaskets [Re: formula S] #246168
03/09/09 06:14 PM
03/09/09 06:14 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Thanks for the replies.
