Reusing copper head gaskets
#246158
03/07/09 08:14 PM
03/07/09 08:14 PM
Posts: 1,200 UK
602heavy
UK
Can the head gaskets be used again?
This is a 400 block , 4.435 bore (.095" over) , heads are O ringed (B1s), CR around 13:1 , is it a simple matter of cleaning the old silicone off & applying some around water ways? , is it necessary to anneal the gaskets?
TIA.
Re: Reusing copper head gaskets
[Re: 602heavy]
#246159
03/07/09 08:25 PM
03/07/09 08:25 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
i used brake cleaner to get the silicone off and 000 steel wool or scotchbrite to scrub it.lacquer thinner final clean and reuse on same head it came from. how much change in color in the copper?
[Re: dOoC]
#246165
03/08/09 05:09 AM
03/08/09 05:09 AM
blownzoom440
ELYRIA,OH
HOW do you heat-it red-hot ? What is te best place to buy these?
i put mine in the oven at 300* untel thay turned blue,air cooled,scotchbrite and then lacquer thinner... there was a comment that as long as the gasket bends easy you dont need to aneal it. easy depends on the thickness i guess.
