Page 1 of 3 1 2 3
Which street drag tires? #2461322
03/05/18 02:51 AM
03/05/18 02:51 AM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Looking for new rubber for my 71 Demon.
530HP/520TQ 4.00" 340 based stroker
3.73 geared Strange Dana 60, custom built to stock A-body dimensions
Caltracs with mono leafs
Stock 4 speed transmission
Custom 15x8 Rallye wheels-Stock offset
Car is mostly street driven, not sure which tires to go with, these are what I'm looking at getting, any thoughts or suggestions appreciated.
(Summit Racing is the vendor)
Mickey Thompson 90000024643 - Mickey Thompson ET Street R Bias-Ply Tires, ET Street R, 28x11.50-15, Bias-Ply
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461328
03/05/18 03:38 AM
03/05/18 03:38 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
MT ET Street Radial or if your a bit more serious with the drags go the same but PRO Radial. I would stay away from a ply tire for lots of street driving.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461329
03/05/18 03:42 AM
03/05/18 03:42 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
These are mine, very sticky on the track and nice on the road, only issue is they don't have a lot of tread depth to start with.
1971 Barracuda
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461330
03/05/18 03:47 AM
03/05/18 03:47 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Another vote for M/T!
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461336
03/05/18 04:26 AM
03/05/18 04:26 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Car is a 4 speed car, most feel that a bias ply will work better than a radial. I am currently running MT drag radials and like them but they are worn out and a new set is needed. The Caltracs & Dana are new so I figured its time to make the switch to DOT Bias Plys
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461340
03/05/18 04:40 AM
03/05/18 04:40 AM
Sydney Australia
sr440 Offline
sr440  Offline
Sydney Australia
If you are running a 4 speed.... forget about using radials.
Re: Which street drag tires? [Re: sr440] #2461345
03/05/18 05:21 AM
03/05/18 05:21 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I agree , accepted wisdom backed up by results .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461346
03/05/18 05:28 AM
03/05/18 05:28 AM
Forget about using any decent radial on the street with a four speed unless your willing and able to slip the clutch a lot when leaving hard from a dead stop twocents
My choice would and has been M/T ET Street tires as big as you can fit and try 12Lbs. or less when you want it to hook hard up
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461382
03/05/18 10:51 AM
03/05/18 10:51 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
American racer L60-15
Re: Which street drag tires? [Re: scatpacktom] #2461391
03/05/18 11:21 AM
03/05/18 11:21 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I have had good luck with Hoosier QuickTime Pros. Work great street or track and tend to like more air pressure.
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461399
03/05/18 11:33 AM
03/05/18 11:33 AM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
I think a radial would work ok at your power level with the four speed. Especially if you are going to be on the street more than the track. M/T street radials drives and handles nice.
Re: Which street drag tires? [Re: Uncle Barry] #2461407
03/05/18 12:10 PM
03/05/18 12:10 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Love my 275 ET Street Pro's!
'63 Dodge 330
11.19 @ 121 mph
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461418
03/05/18 12:34 PM
03/05/18 12:34 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Mickey Thompson Drag Radial, I have been through a few sets and seldom had a traction problem.
68 Barracuda Formula S 340
Re: Which street drag tires? [Re: Bad340fish] #2461444
03/05/18 01:14 PM
03/05/18 01:14 PM
fullmetaljacket Offline
Quick Times Pro's.
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461481
03/05/18 02:34 PM
03/05/18 02:34 PM
central il.
second 70 Offline
second 70  Offline
central il.
Scott MT Street R 28 x 11.5 x 15 8" rims if you want bias ply. I had no luck with radials and my 4 speed hemi.
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461487
03/05/18 02:43 PM
03/05/18 02:43 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Another vote for QTP’s.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461641
03/05/18 08:01 PM
03/05/18 08:01 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks guys....I never even thought of QTP's (or American racer L60-15's for that matter). Question, while checking into the QTP's they are pretty adamant about saying "For Off Road Use Only", obviously they are a thinly disguised drag slick but are they truly unsafe on the street (wet roadways aside)? The MT and AR's don't offer such harsh warnings as far as I am aware?
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461647
03/05/18 08:17 PM
03/05/18 08:17 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
I have driven hundreds and hundreds of street miles on QTP’s nice tires
The 28 by 11.5( 28 by 10 wide) fits nicely on a Demon/ Duster with correct backspace wheel.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Which street drag tires? [Re: B3422W5] #2461662
03/05/18 09:03 PM
03/05/18 09:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Me too and I'd put tubes in em cos the sidewalls are thin and my mid 9-second Dart kills em........... beer
Re: Which street drag tires? [Re: ScottSmith_Harms] #2461677
03/05/18 09:24 PM
03/05/18 09:24 PM
Washington
W
weedburner Offline
weedburner  Offline
W
Washington
Radials with a 4spd is easier than you might think, likely quicker/faster and better mpg as well.
Page 1 of 3 1 2 3
