Re: Which street drag tires?
[Re: ScottSmith_Harms]
#2461328
03/05/18 03:38 AM
03/05/18 03:38 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
MT ET Street Radial or if your a bit more serious with the drags go the same but PRO Radial. I would stay away from a ply tire for lots of street driving.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: sr440]
#2461345
03/05/18 05:21 AM
03/05/18 05:21 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
If you are running a 4 speed.... forget about using radials. I agree , accepted wisdom backed up by results . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Uncle Barry]
#2461407
03/05/18 12:10 PM
03/05/18 12:10 PM
Posts: 4,680 Wichita
GY3
Wichita
Love my 275 ET Street Pro's!
#2461418
03/05/18 12:34 PM
03/05/18 12:34 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Mickey Thompson Drag Radial, I have been through a few sets and seldom had a traction problem.
68 Barracuda Formula S 340
#2461647
03/05/18 08:17 PM
03/05/18 08:17 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
Thanks guys....I never even thought of QTP's (or American racer L60-15's for that matter). Question, while checking into the QTP's they are pretty adamant about saying "For Off Road Use Only", obviously they are a thinly disguised drag slick but are they truly unsafe on the street (wet roadways aside)? The MT and AR's don't offer such harsh warnings as far as I am aware? I have driven hundreds and hundreds of street miles on QTP’s nice tires The 28 by 11.5( 28 by 10 wide) fits nicely on a Demon/ Duster with correct backspace wheel.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2461662
03/05/18 09:03 PM
03/05/18 09:03 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Me too and I'd put tubes in em cos the sidewalls are thin and my mid 9-second Dart kills em...........
