B block hydraulic lifters #2457800
02/26/18 11:46 AM
02/26/18 11:46 AM
Minnesota
peabodyracing Offline OP
Minnesota
I'm sorry to have to ask but I am once again stumped.
Picked up a 383, '66 casting date machined block, crank, etc. that someone had never gotten around to assembling.
Looking at flat tappet hydraulic lifters and find some, but not all, make a distinction on year; many list '68 up, but some don't even mention it.
Is there actually a difference in lifters between 67 back and 68 up?
Thanks in advance!
Lead, follow or get the hell out of the way
Re: B block hydraulic lifters [Re: peabodyracing] #2457820
02/26/18 12:50 PM
02/26/18 12:50 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
67 and older had small cup in lifter, and used a matched small tipped pushrod.
Re: B block hydraulic lifters [Re: buildanother] #2457847
02/26/18 01:28 PM
02/26/18 01:28 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Exactly.
As long as you use lifters and pushrods for the same year applcation(67 down/68 up), there is no problem.
Re: B block hydraulic lifters [Re: fast68plymouth] #2457855
02/26/18 01:45 PM
02/26/18 01:45 PM
The early, pre 1967 pushrods, are a different effective length also shruggy scope
Re: B block hydraulic lifters [Re: Cab_Burge] #2458077
02/26/18 09:14 PM
02/26/18 09:14 PM
Minnesota
Minnesota
I'll be darned. Thanks much guys.
Re: B block hydraulic lifters [Re: peabodyracing] #2458377
02/27/18 01:58 PM
02/27/18 01:58 PM
Correct me if I am wrong but if you order the common 68 up lifers/pushrods you're all set.
