B block hydraulic lifters
#2457800
02/26/18 11:46 AM
02/26/18 11:46 AM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
I'm sorry to have to ask but I am once again stumped.
Picked up a 383, '66 casting date machined block, crank, etc. that someone had never gotten around to assembling.
Looking at flat tappet hydraulic lifters and find some, but not all, make a distinction on year; many list '68 up, but some don't even mention it.
Is there actually a difference in lifters between 67 back and 68 up?
Thanks in advance!
Lead, follow or get the hell out of the way
Re: B block hydraulic lifters
[Re: buildanother]
#2457847
02/26/18 01:28 PM
02/26/18 01:28 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
67 and older had small cup in lifter, and used a matched small tipped pushrod. Exactly. As long as you use lifters and pushrods for the same year applcation(67 down/68 up), there is no problem.
[Re: Cab_Burge]
#2458077
02/26/18 09:14 PM
02/26/18 09:14 PM
peabodyracing
Minnesota
I'll be darned. Thanks much guys.
[Re: peabodyracing]
#2458377
02/27/18 01:58 PM
02/27/18 01:58 PM
RapidRobert
Picked up a 383, '66 casting date machined block, crank, etc. that someone had never gotten around to assembling. Correct me if I am wrong but if you order the common 68 up lifers/pushrods you're all set.
