8082 1050 dominator 2 circuit metering blocks #2456378
02/23/18 11:20 PM
02/23/18 11:20 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
After a failed attempt to make this csrb work with E-85 I am stripping it down and replacing all the E-85 parts and going back to racing gas, I am going to change the boosters in the main body but need some info on what main metering blocks to use, I have narrowed it down to Quick fuel or BLP blocks but am having trouble figuring out which ones I need for a race only 2 circuit carb, it seems a little confuzing to me as to what part number's I need,, I do want to run a powervalve in the front but none in the secondarys, carb guru's??
Re: 8082 1050 dominator 2 circuit metering blocks [Re: dartman366] #2456452
02/24/18 01:05 AM
02/24/18 01:05 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I’d PM thumper dart he is making some nice carbs
Re: 8082 1050 dominator 2 circuit metering blocks [Re: dartman366] #2456463
02/24/18 01:24 AM
02/24/18 01:24 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
iagree
X2. Get in touch with Thumper
Re: 8082 1050 dominator 2 circuit metering blocks [Re: dartman366] #2456464
02/24/18 01:30 AM
02/24/18 01:30 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I can calibrate blocks for ya but really suggest t-slot jets in the main body to finer tune the whole carb............. callme
Re: 8082 1050 dominator 2 circuit metering blocks [Re: Thumperdart] #2456759
02/24/18 04:58 PM
02/24/18 04:58 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Hey thumper what do you think of the new get em blocks?
Are they expensive?
Thanks for your professional opinion in advance.
Don
Re: 8082 1050 dominator 2 circuit metering blocks [Re: cudadon] #2456802
02/24/18 05:48 PM
02/24/18 05:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Heard they are top of the line pro-stock type of stuff and pricey but don't really think the cost justify's our needs at our power level but could be wrong............... thumbs
Re: 8082 1050 dominator 2 circuit metering blocks [Re: Thumperdart] #2456849
02/24/18 06:43 PM
02/24/18 06:43 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Almost everyone that I know that tried E85 finally switched over to alcohol. Most are EXTREMELY happy. Send it to APD and join the "happy crowd". I said I would NEVER do it and now I would never go bracket racing with anything else.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 8082 1050 dominator 2 circuit metering blocks [Re: pittsburghracer] #2457434
02/25/18 06:58 PM
02/25/18 06:58 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
I switched back to gas several years ago and the car became happy again so I am going to listen to the car and stay with gas, I have a station just down the street that sells VP bulk and their prices are reasonable, If I were racing every weekend then mabey I would go to moonshine, I just need to get this other carb back together with good parts and dialed in, the 3 circuit works well but needs tuned in for this motor, the only thing that has been changed is I put new Quick fuel bowls on it to make it easier to set the float level with the big windows, it still has the origional metering blocks and boosters.
Re: 8082 1050 dominator 2 circuit metering blocks [Re: dartman366] #2457510
02/25/18 08:58 PM
02/25/18 08:58 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
Well if you want to take one more swing at things, I'd give these guys a call: http://www.classicmtrsprts.com/
I pay out the waazoo for a pail of C-12, but I know how the car is going to act every time. Is what it is...
