1970 Roadrunner Dash reverse light ground #2456445
02/24/18 12:44 AM
02/24/18 12:44 AM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
Hello been a while since i been on here here's my Question the reverse dash light that goes into the plastic overlay on the dash what did the ground wire look like that fastened to the light bezel i can make a ground But.....I want to know what was the original ground looked like to make one or Buy one? the oval cut out in the dash frame does not contact the reverse light THANKS MOPARTS FOR THE AD and to all that can Help Dan
Re: 1970 Roadrunner Dash reverse light ground [Re: HEMI ROY] #2456448
02/24/18 12:53 AM
02/24/18 12:53 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Doesn't the trans switch supply the ground?
Re: 1970 Roadrunner Dash reverse light ground [Re: HEMI ROY] #2456450
02/24/18 01:01 AM
02/24/18 01:01 AM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
the light that goes into the dash bezel is 1 wire so it has a power wire no ground this car was orig 3 spd so i put the hole in the dash in correct location and the correct harness for trans up to wiper motor even in wiring diagram shows a ground symbol but no details theres a 70 dash complete on ebay for sale shows reverse light just isnt clear enough to see what they used or did Thanks Dan
Re: 1970 Roadrunner Dash reverse light ground [Re: HEMI ROY] #2456474
02/24/18 01:49 AM
02/24/18 01:49 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Had a 68 coronet here and reverse light was mounted to metal dash, so no extra ground was needed. Not sure about 1970's.
Re: 1970 Roadrunner Dash reverse light ground [Re: HEMI ROY] #2456480
02/24/18 02:02 AM
02/24/18 02:02 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Behind the front plastic overlay is the dash metal frame, this provides the ground for the reverse lite by its mounting...
Just my $0.02.. wink
Re: 1970 Roadrunner Dash reverse light ground [Re: HEMI ROY] #2456561
02/24/18 09:49 AM
02/24/18 09:49 AM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
the dash opening is about 2 x 3 inch oval cut out init factory stamp
Re: 1970 Roadrunner Dash reverse light ground [Re: HEMI ROY] #2456666
02/24/18 02:23 PM
02/24/18 02:23 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
Don’t know if this helps or not cause the attachments won’t open on my phone.
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1176725/1970-b-body-reverse-light.html
68 Charger R/T 440 auto
Re: 1970 Roadrunner Dash reverse light ground [Re: HEMI ROY] #2456751
02/24/18 04:48 PM
02/24/18 04:48 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Dan,
In 70 there are two wires that run to the light. One purple and the other black with a white trace.
I just checked this on my unrestored 70 GTX
Re: 1970 Roadrunner Dash reverse light ground [Re: Morty426] #2456771
02/24/18 05:07 PM
02/24/18 05:07 PM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
Poor picture of mine but this is what it looks like
Re: 1970 Roadrunner Dash reverse light ground [Re: HEMI ROY] #2456982
02/24/18 10:39 PM
02/24/18 10:39 PM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
Awsum i knew it was something like that do you have any extra to sell what does the other end look like where does it connect to Thank You !!!
Re: 1970 Roadrunner Dash reverse light ground [Re: HEMI ROY] #2457012
02/24/18 11:15 PM
02/24/18 11:15 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
They are relatively cheap on ebay. I'm redoing my GTX dash right now. Lots and lots of wires......
Re: 1970 Roadrunner Dash reverse light ground [Re: 70HemiGTX] #2457061
02/25/18 12:13 AM
02/25/18 12:13 AM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
70HemiGTX do you have any pics of yours apart i can see ??? I have the dash light but mine doesn't or does any others have the ground wire on them everyone is missing the question LoL. I can make one but i want an orig ground
Re: 1970 Roadrunner Dash reverse light ground [Re: Morty426] #2457065
02/25/18 12:19 AM
02/25/18 12:19 AM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
M do you have any extra one to sell or can i see pics of it apart both ends Thanks Dan
Re: 1970 Roadrunner Dash reverse light ground [Re: HEMI ROY] #2457232
02/25/18 12:01 PM
02/25/18 12:01 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I can take a pic of mine later today. Are you looking for the lenght of the ground wire? It is probably about 6" long with a ring end on it for a screw to go through. mccanix's pic. is exactly like the back of mine.
Re: 1970 Roadrunner Dash reverse light ground [Re: 70HemiGTX] #2457267
02/25/18 01:06 PM
02/25/18 01:06 PM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
Thank You yes and where do they have it grounded too do you have any extras reverse lights or ground wires are they fixed to the actual light socket
Re: 1970 Roadrunner Dash reverse light ground [Re: HEMI ROY] #2457273
02/25/18 01:14 PM
02/25/18 01:14 PM
moparx Offline
moparx  Offline
roy, you can easily solder a ground wire to any metal socket if needed. i have also seen examples of ground wires attached to the outside barrel of the socket with a hose clamp. but i don't recommend that other than a temporary repair.
beer
Re: 1970 Roadrunner Dash reverse light ground [Re: HEMI ROY] #2457340
02/25/18 03:33 PM
02/25/18 03:33 PM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
Thank You Yeah i know how to make it ground but... i was just wanting an orig or a good pic of an orig one to make it right as i can
Re: 1970 Roadrunner Dash reverse light ground [Re: HEMI ROY] #2457343
02/25/18 03:39 PM
02/25/18 03:39 PM
BRIDGEWATER, CT.
WINGNUT Offline
WINGNUT  Offline
BRIDGEWATER, CT.
About 4 inches to the right of the steering column, there is a hole drilled through on the lower bottom edge lip of the dash frame. A clip with s screw is used for the ground wire. Here is a pic of the clip and screw. WINGNUT
Re: 1970 Roadrunner Dash reverse light ground [Re: HEMI ROY] #2457549
02/25/18 10:16 PM
02/25/18 10:16 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Yes that's the ground screw and clip. Here is a pic of the light socket.
Re: 1970 Roadrunner Dash reverse light ground [Re: HEMI ROY] #2457620
02/25/18 11:48 PM
02/25/18 11:48 PM
INDIANA
HEMI ROY Offline OP
HEMI ROY  Offline OP
INDIANA
Awsume would you want to sell this ???
