#2456022 - 02/23/18 07:10 AM Mds delete question
68shifter Online   content
Loc: MI
Just curious if anyone has just used soft plugs in place of buying the mds delete plugs? Not that the plugs are expensive but just curious if there's any reason you couldn't do it? Thanks.
#2456113 - 02/23/18 10:50 AM Re: Mds delete question [Re: 68shifter]
RTSrunner Online   content
Loc: Pittsburgh,PA
I have a couple blocks here but none are MDS.Since the solenoids or plugs are in the oil galley an oil pressure drop could happen if neither are used to direct the flow.
#2456330 - 02/23/18 06:08 PM Re: Mds delete question [Re: 68shifter]
HotRodDave Offline
Loc: Kalispell Mt.
a soft plug will not work, the oil will squirt out the bypass hole and flood the rocker area, may even drain the pan as well as a drop in oil pressure.
68 cuda 360 notchback SOLD
1996 Ram 2500 5.9 eddy intake EQ heads, mild cam upgrade great tow rig!
#2456927 - 02/24/18 05:48 PM Re: Mds delete question [Re: 68shifter]
JT612GTX Offline
Loc: Otsego, mi. by Martin 131 stri...
Use the mds delete plugs, they work fine,
put them on a rebuilt 5.7 long block for my 05 Ram,
prime the engine before starting, check oil pressure!
86 Daytona - 612/ glide - 2400lbs - 8.60 alot more left
71 S/G Challenger - 469/glide - 2800lbs - 9.20s and tuning
70 Challenger - mild 440/727 - 3475lbs - 10.96 best
70 GTX - future quick 16? more $$$$$$
#2456963 - 02/24/18 07:14 PM Re: Mds delete question [Re: 68shifter]
HotRodDave Offline
Loc: Kalispell Mt.
If you use just the MDS delete plugs without replacing the MDS lifters your engine will only run on 4 cylinders.
#2457126 - 02/24/18 11:35 PM Re: Mds delete question [Re: HotRodDave]
GoodysGotaCuda Offline
5.7L Hemi, 6spd
Loc: Texas
this is true fan
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - Build page -> https://www.facebook.com/GoodysGotaHemi<-
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
2016 BMW X1, 2016 Subaru WRX
#2457185 - 02/25/18 05:25 AM Re: Mds delete question [Re: 68shifter]
Loc: MI
It's getting delete lifters. Just curious on the soft plugs. Ordered the delete plugs.
I think you could actually do two soft plugs, essentially one each where the orings are on the delete plugs but I'm not messing with it over 50 bucks.
#2457196 - 02/25/18 07:30 AM Re: Mds delete question [Re: HotRodDave]
ric3xrt Offline
Loc: Trumbauersville PA
+10000000000000000000000000000000000000
it will not work it bleeds off pressure , I pulled a wrecked Molnar crank and some burned up Oliver rods from a short block that someone (not me) tried it on.
Truth has no agenda, but those with an agenda don't always acknowledge truth
74 D100 D-Code,3x75 D100 D-code, 3x77 D100 D-code,6x78 D150 D-D-code...lots of pre 81 trucks
75 4x2 Ramcharger....G3 coming soon
2003 Ram st
2004 Rumble Bee
2004 Ram GTX(Plum Crazy)
2005 Ram GTXtreme(s Plum Crazy,Banana Yellow)
Any info on these trucks is greatly appreciated
2005 Ram 1500 (drag truck in building)
2014 1500 tradesman(shhhh, it's hiding a 7.0 short block under those eagle heads.
#2458053 - 02/26/18 05:23 PM Re: Mds delete question [Re: 68shifter]
JT612GTX Offline
I failed to mention my trucks not wired for mds, the engine was built using
regular lifters, the reman block just had the holes for mds, so yes your right,need the right ones, I just had to plug the holes.
25,338 Registered Members
190,103 Topics
Low Oil Pressure
by Stroker Scamp
06/17/18 09:06 PM
ethonal free gas stations in carlisle?
by 3wracing
06/17/18 09:03 PM
Body plugs in a 71 b body.
by 71sat440
06/17/18 08:20 PM
92 W250 w/ CTD wiper issue
by volaredon
06/17/18 08:09 PM
