Re: Mds delete question
[Re: 68shifter]
#2456330
02/23/18 09:08 PM
02/23/18 09:08 PM
Posts: 12,406 Kalispell Mt.
HotRodDave
Kalispell Mt.
a soft plug will not work, the oil will squirt out the bypass hole and flood the rocker area, may even drain the pan as well as a drop in oil pressure.
[Re: 68shifter]
#2456927
02/24/18 08:48 PM
02/24/18 08:48 PM
Posts: 43 Otsego, mi. by Martin 131 stri...
JT612GTX
Use the mds delete plugs, they work fine, put them on a rebuilt 5.7 long block for my 05 Ram, prime the engine before starting, check oil pressure!
86 Daytona - 612/ glide - 2400lbs - 8.60 alot more left 71 S/G Challenger - 469/glide - 2800lbs - 9.20s and tuning 70 Challenger - mild 440/727 - 3475lbs - 10.96 best 70 GTX - future quick 16? more $$$$$$
[Re: 68shifter]
#2456963
02/24/18 10:14 PM
02/24/18 10:14 PM
HotRodDave
Kalispell Mt.
If you use just the MDS delete plugs without replacing the MDS lifters your engine will only run on 4 cylinders.
[Re: HotRodDave]
#2457196
02/25/18 10:30 AM
02/25/18 10:30 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
a soft plug will not work, the oil will squirt out the bypass hole and flood the rocker area, may even drain the pan as well as a drop in oil pressure. +10000000000000000000000000000000000000 it will not work it bleeds off pressure , I pulled a wrecked Molnar crank and some burned up Oliver rods from a short block that someone (not me) tried it on.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: 68shifter]
#2458053
02/26/18 08:23 PM
02/26/18 08:23 PM
JT612GTX
I failed to mention my trucks not wired for mds, the engine was built using regular lifters, the reman block just had the holes for mds, so yes your right,need the right ones, I just had to plug the holes.
