Pressure check a Hemi or whatever block #2454897
02/21/18 01:17 AM
02/21/18 01:17 AM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Got an idea of how I should do this but checking with you guys on your ways.
Re: Pressure check a Hemi or whatever block [Re: cudaman1969] #2454901
02/21/18 01:21 AM
02/21/18 01:21 AM
Cab_Burge Online work
Cab_Burge  Online Work
You can bolt it together with the heads and put a pressure inlet port and gauge on block plates on the water pump inlet and outlets(both sides) and apply air pressure and get a spray bottle of soapy water and go searching all over the heads and block scope
I've used a torque plate to pressure check aluminum heads that had been welded on, that works also up
Re: Pressure check a Hemi or whatever block [Re: Cab_Burge] #2454911
02/21/18 01:45 AM
02/21/18 01:45 AM
fredericksburg,va
fredericksburg,va
So you use air instead of water? At what pressure? Would an engine "see" 20# or more pressure running?
Re: Pressure check a Hemi or whatever block [Re: cudaman1969] #2454919
02/21/18 02:11 AM
02/21/18 02:11 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Air pressure works. But you want to pressure test it assembled. If you have one, a leakdown tester will show pressure loss. A squirt bottle with water only works on external surfaces but you can have internal leaks. 20 lbs is plenty - rad caps are rated at what ... 15 psi? So you don't need much more than that.
Re: Pressure check a Hemi or whatever block [Re: cudaman1969] #2454923
02/21/18 02:23 AM
02/21/18 02:23 AM
AndyF Offline
AndyF  Offline
Re: Pressure check a Hemi or whatever block [Re: cudaman1969] #2454925
02/21/18 02:33 AM
02/21/18 02:33 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Engine in car or bare block on the stand?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Pressure check a Hemi or whatever block [Re: AndyF] #2454966
02/21/18 05:30 AM
02/21/18 05:30 AM
Originally Posted By AndyF
That's what I'm talking about up I made my own out of 3/8 plate steel shruggy
Re: Pressure check a Hemi or whatever block [Re: hemi-itis] #2454967
02/21/18 05:32 AM
02/21/18 05:32 AM
Your choice, it will, or should test the same either way work Probably easier on the stand so you can look at the back, sides and front of the motor on the stand up
Re: Pressure check a Hemi or whatever block [Re: cudaman1969] #2454969
02/21/18 05:35 AM
02/21/18 05:35 AM
I don't use water in the block or heads tsk Air pressure and soapy water, on the aluminum heads that had cracks and had been welded on already I used 30+ Lbs. of air pressure to make sure they where sealed up after having those welds welded up over again up
Re: Pressure check a Hemi or whatever block [Re: cudaman1969] #2455050
02/21/18 01:09 PM
02/21/18 01:09 PM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
Not to get off subject but, how long should the pressure hold in the system without any loss?
Digger73 (Mike(
I live with fear everyday but, sometimes she lets me race!
Re: Pressure check a Hemi or whatever block [Re: cudaman1969] #2455058
02/21/18 01:29 PM
02/21/18 01:29 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I had rust in the cylinder and I did what I had to to check it. Block check
Re: Pressure check a Hemi or whatever block [Re: cudaman1969] #2455060
02/21/18 01:35 PM
02/21/18 01:35 PM
an8sec70cuda Offline
Unless the leak/crack/hole is really bad, a cast iron block or cylinder head will most likely not show a leak unless you can heat it up. Pressure checking one cold and it not showing any leakage doesn't prove anything.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Pressure check a Hemi or whatever block [Re: an8sec70cuda] #2455063
02/21/18 01:42 PM
02/21/18 01:42 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
There have been posts with heat coils going into the block moving hot water.I pre heated the block,put in hot water then seald and continued heating it
Re: Pressure check a Hemi or whatever block [Re: cudaman1969] #2455079
02/21/18 02:14 PM
02/21/18 02:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
As to pressure test with no loss. I recently left my Cummins over 24 hours with no pressure lost. Yet when it was warm it would weep coolant that I could smell but not ever see. Turned out I left the head bolt at the very rear under the cowl finger tight. I'd use 30 psi with soap water.
Doug
Re: Pressure check a Hemi or whatever block [Re: cudaman1969] #2455172
02/21/18 05:24 PM
02/21/18 05:24 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Uh, forever. Anything less would be a leak, right ?!?!?
Re: Pressure check a Hemi or whatever block [Re: an8sec70cuda] #2455173
02/21/18 05:26 PM
02/21/18 05:26 PM
I've used a propane torch to heat up cast iron to see a crack better, it does make them rascals appear a lot easeir up
Re: Pressure check a Hemi or whatever block [Re: hemi-itis] #2455216
02/21/18 06:54 PM
02/21/18 06:54 PM
fredericksburg,va
fredericksburg,va
On a stand, bare block. I was going to make a head plate of 1/4 aluminum but the kit said without a head it needed a torque plate.? I figured 40 psi would show any cracks, no mater how hot it is. But that's why I'm asking.
Re: Pressure check a Hemi or whatever block [Re: cudaman1969] #2455218
02/21/18 07:02 PM
02/21/18 07:02 PM
The pressure test rack I used at the machine shop would go to 35 psi (IIRC) and it wouldn't make a crack bubble on a cold cast iron head...one we knew was leaking on the car.
CHIP
Re: Pressure check a Hemi or whatever block [Re: Digger73] #2455262
02/21/18 08:33 PM
02/21/18 08:33 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Shouldn't leak at all if sealed up good. May have a little fluctuation with temperature change.
