Re: Pressure check a Hemi or whatever block
[Re: hemi-itis]
#2454967
02/21/18 05:32 AM
02/21/18 05:32 AM
Posts: 43,123 Bend,OR USA
Cab_Burge
Engine in car or bare block on the stand? Your choice, it will, or should test the same either way Probably easier on the stand so you can look at the back, sides and front of the motor on the stand
[Re: cudaman1969]
#2454969
02/21/18 05:35 AM
02/21/18 05:35 AM
Cab_Burge
You can bolt it together with the heads and put a pressure inlet port and gauge on block plates on the water pump inlet and outlets(both sides) and apply air pressure and get a spray bottle of soapy water and go searching all over the heads and block I've used a torque plate to pressure check aluminum heads that had been welded on, that works also So you use air instead of water? At what pressure? Would an engine "see" 20# or more pressure running? I don't use water in the block or heads Air pressure and soapy water, on the aluminum heads that had cracks and had been welded on already I used 30+ Lbs. of air pressure to make sure they where sealed up after having those welds welded up over again
[Re: cudaman1969]
#2455050
02/21/18 01:09 PM
02/21/18 01:09 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
Not to get off subject but, how long should the pressure hold in the system without any loss?
Digger73 (Mike(
I live with fear everyday but, sometimes she lets me race!
[Re: cudaman1969]
#2455060
02/21/18 01:35 PM
02/21/18 01:35 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Unless the leak/crack/hole is really bad, a cast iron block or cylinder head will most likely not show a leak unless you can heat it up. Pressure checking one cold and it not showing any leakage doesn't prove anything.
[Re: an8sec70cuda]
#2455063
02/21/18 01:42 PM
02/21/18 01:42 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Unless the leak/crack/hole is really bad, a cast iron block or cylinder head will most likely not show a leak unless you can heat it up. Pressure checking one cold and it not showing any leakage doesn't prove anything. There have been posts with heat coils going into the block moving hot water.I pre heated the block,put in hot water then seald and continued heating it
[Re: cudaman1969]
#2455172
02/21/18 05:24 PM
02/21/18 05:24 PM
Posts: 8,862 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Not to get off subject but, how long should the pressure hold in the system without any loss? Uh, forever. Anything less would be a leak, right ?!?!?
[Re: hemi-itis]
#2455216
02/21/18 06:54 PM
02/21/18 06:54 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
Engine in car or bare block on the stand? On a stand, bare block. I was going to make a head plate of 1/4 aluminum but the kit said without a head it needed a torque plate.? I figured 40 psi would show any cracks, no mater how hot it is. But that's why I'm asking.
[Re: cudaman1969]
#2455218
02/21/18 07:02 PM
02/21/18 07:02 PM
an8sec70cuda
The pressure test rack I used at the machine shop would go to 35 psi (IIRC) and it wouldn't make a crack bubble on a cold cast iron head...one we knew was leaking on the car.
