A Carter Thermo-Quad Guide ( tqguide-Vaanth ) #2453658
02/18/18 10:40 PM
02/18/18 10:40 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
Is there somebody able to update this website:
http://www.carbkitsource.com/tech/Carter/pages/tqguide-Vaanth.html
I found a carb locally which on listing doesn't get listed the rods, primary and secondary jets sizes and I got them
6394
rod---1941
secondary jet---5137
waiting to get cleaned the primary jets to figure it out
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth ) [Re: NachoRT74] #2453707
02/18/18 11:54 PM
02/18/18 11:54 PM
Hello Nacho, on a side note did you ever hear back from our Aussie buddy on the .008" lifters?
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth ) [Re: NachoRT74] #2453719
02/19/18 12:08 AM
02/19/18 12:08 AM
Valencia, España
Valencia, España
I simply gave up!
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth ) [Re: NachoRT74] #2453728
02/19/18 12:34 AM
02/19/18 12:34 AM
Me too after several attempts
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth ) [Re: NachoRT74] #2453910
02/19/18 01:45 PM
02/19/18 01:45 PM
Valencia, España
Valencia, España
HARD to tell the primary size. One is sanded and this one reads...
095? Maybe?
095 seems to be pretty much standard primaries for 340
Can't find specs for 1941 rods
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth ) [Re: NachoRT74] #2454746
02/20/18 08:57 PM
02/20/18 08:57 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I have seen that list many, many times over the years. But I've never seen an update to it.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth ) [Re: NachoRT74] #2454755
02/20/18 09:10 PM
02/20/18 09:10 PM
Nacho you might get a round wooden dowel & sand it till it JUST FITS all the way thru then mike it
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth ) [Re: NachoRT74] #2454795
02/20/18 10:21 PM
02/20/18 10:21 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
If you can, find a drill index and use bits as gauges.
Use the blank end that goes in drill not the sharp end.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth ) [Re: NachoRT74] #2454821
02/20/18 10:52 PM
02/20/18 10:52 PM
5thAve Online content
5thAve  Online Content
Did you try emailing the person who runs the site?
They might not be updating that page since that's not the original site for the vaanth guide and there are several other sites with it floating around.
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth ) [Re: NachoRT74] #2455002
02/21/18 10:51 AM
02/21/18 10:51 AM
Valencia, España
Valencia, España
yes I guess that. But IF SOMEBODY CARES and knows the guy who originally wrotte that nice info, well I got a carb with missed specs on the table.
Guys I have a dig caliper that maybe could work ( if ends fits on opening )
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth ) [Re: steve660] #2455056
02/21/18 01:25 PM
02/21/18 01:25 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
This looks to be a very good option.
I have mechanical Aptitude.
I can screw up anything.
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth ) [Re: NachoRT74] #2455521
02/22/18 11:17 AM
02/22/18 11:17 AM
Valencia, España
Valencia, España
I don't have any drill index handy.
The stamped number doesn't look to be an 8, and I can't find any fact 96s were available, so my guess is simply a 95 being the fact mostly of factory setups used 95s
still have to search the 1941 rods specs
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth ) [Re: NachoRT74] #2455558
02/22/18 12:49 PM
02/22/18 12:49 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've seen Vaanth's thermoquad guide floating around the internet for 15 years now. The page says it was written by Gary Lewallen in 1998. That was 20 years ago! He also has a page in the moparts tech archive from the old mopar mailing list on the 8.75 diff. Gary assembled a wealth of knowledge for us years ago when all that was available had to still be dug out of books, magazines and catalogs. If Gary is still alive it would be fun to hear from him and hear about his history with the hobby.
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth ) [Re: NachoRT74] #2455847
02/22/18 10:10 PM
02/22/18 10:10 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth ) [Re: NachoRT74] #2455949
02/23/18 01:38 AM
02/23/18 01:38 AM
Valencia, España
Valencia, España
grrrrreat
1941 .073 .061 .045
thanks. I have read that website long time ago once but didn't remember all the info there
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth ) [Re: NachoRT74] #2456358
02/23/18 10:27 PM
02/23/18 10:27 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
