A Carter Thermo-Quad Guide ( tqguide-Vaanth )
#2453658
02/18/18 10:40 PM
02/18/18 10:40 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Is there somebody able to update this website: http://www.carbkitsource.com/tech/Carter/pages/tqguide-Vaanth.htmlI found a carb locally which on listing doesn't get listed the rods, primary and secondary jets sizes and I got them 6394 rod---1941 secondary jet---5137 waiting to get cleaned the primary jets to figure it out
Re: A Carter Thermo-Quad Guide ( tqguide-Vaanth )
[Re: NachoRT74]
#2453707
02/18/18 11:54 PM
02/18/18 11:54 PM
RapidRobert
Hello Nacho, on a side note did you ever hear back from our Aussie buddy on the .008" lifters?
[Re: NachoRT74]
#2453728
02/19/18 12:34 AM
02/19/18 12:34 AM
RapidRobert
Me too after several attempts
[Re: NachoRT74]
#2453910
02/19/18 01:45 PM
02/19/18 01:45 PM
NachoRT74
Valencia, España
HARD to tell the primary size. One is sanded and this one reads...
095? Maybe?
095 seems to be pretty much standard primaries for 340
Can't find specs for 1941 rods
[Re: NachoRT74]
#2454755
02/20/18 09:10 PM
02/20/18 09:10 PM
RapidRobert
HARD to tell the primary size. Nacho you might get a round wooden dowel & sand it till it JUST FITS all the way thru then mike it
[Re: NachoRT74]
#2454795
02/20/18 10:21 PM
02/20/18 10:21 PM
Posts: 289 Lowes
steve660
Lowes
If you can, find a drill index and use bits as gauges. Use the blank end that goes in drill not the sharp end.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: NachoRT74]
#2455002
02/21/18 10:51 AM
02/21/18 10:51 AM
NachoRT74
Valencia, España
yes I guess that. But IF SOMEBODY CARES and knows the guy who originally wrotte that nice info, well I got a carb with missed specs on the table.
Guys I have a dig caliper that maybe could work ( if ends fits on opening )
[Re: steve660]
#2455056
02/21/18 01:25 PM
02/21/18 01:25 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
find a drill index and use bits as gauges. This looks to be a very good option.
I have mechanical Aptitude. I can screw up anything.
[Re: NachoRT74]
#2455521
02/22/18 11:17 AM
02/22/18 11:17 AM
NachoRT74
Valencia, España
I don't have any drill index handy.
The stamped number doesn't look to be an 8, and I can't find any fact 96s were available, so my guess is simply a 95 being the fact mostly of factory setups used 95s
still have to search the 1941 rods specs
[Re: NachoRT74]
#2455847
02/22/18 10:10 PM
02/22/18 10:10 PM
Posts: 15,401 Omaha Ne
TJP
Omaha Ne
[Re: NachoRT74]
#2455949
02/23/18 01:38 AM
02/23/18 01:38 AM
NachoRT74
Valencia, España
grrrrreat
1941 .073 .061 .045
thanks. I have read that website long time ago once but didn't remember all the info there
[Re: NachoRT74]
#2456358
02/23/18 10:27 PM
02/23/18 10:27 PM
TJP
Omaha Ne
