Air checking 904 question
#2453596
02/18/18 07:34 PM
02/18/18 07:34 PM
Posts: 184 Memphis,TN
J. Hammer
Memphis,TN
I'm building a 904 and may have a problem during air checking the clutches. The direct seems fine,engages firmly and no air escaping. The rear clutch is a different story. The clutch engages but air escapes from the port next to the port that I apply air pressure, this is the port that goes to the converter? Anyone run into this?
Re: Air checking 904 question
[Re: J. Hammer]
#2454377
02/20/18 02:17 AM
02/20/18 02:17 AM
Posts: 25,802 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Are the pump parts and input shaft original to that trans?
[Re: John_Kunkel]
#2454383
02/20/18 02:23 AM
02/20/18 02:23 AM
J. Hammer
Memphis,TN
The original pump was replaced with a transtar rebuilt pump. Input shaft,drums are original to the trans.
[Re: J. Hammer]
#2455245
02/21/18 08:02 PM
02/21/18 08:02 PM
John_Kunkel
Rio Linda, CA
There was a change in the support and rings, might have a mismatch of parts.
