Max Wedge cooling article #2453171
02/17/18 07:36 PM
02/17/18 07:36 PM
AndyF Offline OP
AndyF  Offline OP
http://www.hotrod.com/articles/robert-foleys-426-max-wedge-powered-1963-polara-overheats-gonna-fix/
Interesting what they did on this car. I think I would've tried using stock parts first but guess they went straight for the aluminum radiator. I think a C body radiator with a good shroud would've worked and looked more stock.
Re: Max Wedge cooling article [Re: AndyF] #2453189
02/17/18 08:41 PM
02/17/18 08:41 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I agree.
The stock radiator was no match for the improved 'heatsource' on the other end.
Had a chuckle when I noticed this pic comparing the 2 waterpumps;
http://st.hotrod.com/uploads/sites/21/20...-sheetmetal.jpg
I've tested a number of these on my own engine and found the factory stock 'childs toy' stamped impeller provided way more flow through the system then the 440source one with the cast impeller.
The cast impeller 'should be' better, but is probably not designed that well.
Re: Max Wedge cooling article [Re: AndyF] #2453215
02/17/18 10:00 PM
02/17/18 10:00 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i was curious about the 440 source pump, the idea of the blade being extremely close to the housing might alleviate the benefit of an anticavitation plate.
i was also looking at some of the edelbrock pumps at summit, looks like the 440source pumps impeller is the same...
Re: Max Wedge cooling article [Re: AndyF] #2453216
02/17/18 10:00 PM
02/17/18 10:00 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It lost a lot of credibility when they wrote "Frame Off Restoration" on the intro page. The aluminum radiator doesn't surprise me (probably a sponsor) as I agree, a good factory 3 or 4 core radiator with a shroud would have done just fine and looked like it belonged there.
Re: Max Wedge cooling article [Re: ScottSmith_Harms] #2453225
02/17/18 10:15 PM
02/17/18 10:15 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The problem is that 99% of the readers, and people out there believe all that crap.
Re: Max Wedge cooling article [Re: ScottSmith_Harms] #2453239
02/17/18 10:53 PM
02/17/18 10:53 PM
AndyF Offline OP
AndyF  Offline OP
Yeah cutting the subframes off of a Mopar just to restore the car seems like the hard way to do it! But I've had some of my articles edited in such a way that they don't make sense anymore. Sometimes an editor will try to simplify a poor sentence and it comes out not making any sense. The writers do not get final approval so the first time I see what I "wrote" is in the grocery store when I look at the magazine.
Re: Max Wedge cooling article [Re: AndyF] #2453249
02/17/18 11:17 PM
02/17/18 11:17 PM
Cab_Burge Online work
Cab_Burge  Online Work
When they mentioned today pump gas with 13.5 to 1 compression my butt cringed no
My real 415 HP M.W. 1963 Plymouth Belvedere car never over heated in the Mojave desert racing it at LACR or driving it on the street on the old 100+ Octane pump gas back in the day with all the original cooling system including the original clutch type aluminum seven bladed fan shruggy
Many people who work on cars today don't know which parts work the best, brass and copper radiators will shed a lot more BTU than aluminum will of the same size and construction work
Re: Max Wedge cooling article [Re: AndyF] #2453252
02/17/18 11:24 PM
02/17/18 11:24 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yea, same here.
Re: Max Wedge cooling article [Re: AndyF] #2453344
02/18/18 03:01 AM
02/18/18 03:01 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Wonder why they didn't just use the factory 7 blade clutch fan?
Chrysler doesn't buy full-page ads (rim shot!).
An electric fan is a great idea, except:
1. if it fails you're restricted to keeping your speed above 40 (which may not do it - the shroud is a big restriction)
2. above 40 you don't need any fan at all
3. you're not really going to keep a spare in the trunk, are you? I've seen 20 X more busted electric fans than mechanical fans - and all the mechanicals had something hit them (the electrics broke all by themselves). The factory fan in my Coupe DeVille ate a cat, chewed it up, and spit it out with no damage (to the fan, the cat was shredded).
It's not so bad - last month one of the staff monkeys explained that "they're called 'funny cars' because the engine isn't the same brand as the chassis". I guess he was born long after 1965. But he could have asked? Who in that magazine would know, or care?
They should re-title it "1968 Camaro Monthly".
Boffin Emeritus
Re: Max Wedge cooling article [Re: AndyF] #2453359
02/18/18 04:03 AM
02/18/18 04:03 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
It is a good looking 63 Dodge as I like the car. Ron
Re: Max Wedge cooling article [Re: AndyF] #2453366
02/18/18 05:27 AM
02/18/18 05:27 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
What bothers me with this Griffin radiator, and the one in my car, it the holes in the brackets don't line up correctly. On mine it looks like the brackets are made correctly, but welded in the wrong place. That is pretty bad for such an expensive radiator.
On their radiator they had to lower it, and on mine, I had to raise it because the lower tank was hitting.
Re: Max Wedge cooling article [Re: 451Mopar] #2453371
02/18/18 09:33 AM
02/18/18 09:33 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I bet if he had put a better fan on it and had overdriven the pump it would be fine.
Radiators get too much focus. Airflow is most important
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Max Wedge cooling article [Re: 6bblFLASH] #2453495
02/18/18 03:24 PM
02/18/18 03:24 PM
Washington
madscientist Offline
Washington
Coolant flow is where it starts. In a hundred MPH wind if you have no flow you won't have cooling.
Re: Max Wedge cooling article [Re: AndyF] #2453527
02/18/18 04:38 PM
02/18/18 04:38 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That has to be the weakest burnout video I've ever seen. blush
I actually prefer the look of an aluminum radiator unless I'm trying to do a 100 point restoration. It looks killer in that car and hopefully works better for him.
Re: Max Wedge cooling article [Re: ProSport] #2453753
02/19/18 01:42 AM
02/19/18 01:42 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Yeah, like a half throttle burnout ?? Surely that thing could top gear @ 6000 on the spot.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Max Wedge cooling article [Re: AndyF] #2453784
02/19/18 03:32 AM
02/19/18 03:32 AM
AndyF Offline OP
AndyF  Offline OP
I put an aluminum radiator in my '65 Coronet but I painted it flat black so it would look stock to the casual eye.
Re: Max Wedge cooling article [Re: AndyF] #2453883
02/19/18 12:54 PM
02/19/18 12:54 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I have the same car and use a '65 radiator, clutch fan and don't even run a shroud and it keeps my '63 cool! I don't attempt to run 13.5:1 CR on the street, either!
~$2k to fix an overheating issue. SMH.
'63 Dodge 330
11.19 @ 121 mph
Re: Max Wedge cooling article [Re: polyspheric] #2453895
02/19/18 01:10 PM
02/19/18 01:10 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
My experience riding along on Drag Week tells me this is not true on all cars.
Bill
Re: Max Wedge cooling article [Re: ScottSmith_Harms] #2453995
02/19/18 04:35 PM
02/19/18 04:35 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
iagree
I bought a 4 core for my 68 RR from these folks.
http://www.usradiator.com/plymouth-road-runner-1966-69-v8-bb-radiator.html
It took 4 -6 weeks to get it as they build it to spec. The fit was perfect. Even the orig. fan shroud holes were in the correct location. I am very pleased the appearance. It cools the 383 the best it ever has been. I am swapping to a 470".
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Max Wedge cooling article [Re: AndyF] #2454000
02/19/18 04:43 PM
02/19/18 04:43 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Assuming that the radiator is big enough for the engine?
Will vary somewhat based on the shape of the nose, exposed radiator core area, air exit path away from the core, etc.
For core area start with 1 square inch per anticipated HP. Of course, this is impossible in those cars - the largest radiator that fits the stock opening is simply way too small. Making the core thicker is a band-aid, can only do so much. A 1,000 HP car can't cool continuously at any large throttle opening.
Boffin Emeritus
