While we're talking rear ends....How about Lube?? #2452695
02/16/18 06:47 PM
02/16/18 06:47 PM
Wisconsin
wkroncke17 Offline OP
Wisconsin
Ok all - I got a good education on what to use to seal 'er up for every scenario....Now she's sealed and will NOT leak (I hope)
What is the best gear lube to run in the pumpkin?
It's a standard width A-body 8 3/4 with a 4:30 - 1 Richmond gear and Richmond Spool turning Dutchman Axles.
It will see track/street time maybe 70/30?
Again, it's been almost 30 years since I've put one back together, and my Dad used to use regular rear end lube, and would always bring me the magic bottle of Direct Connection "Whale Oil" additive that smelled horrible!!!
I'm sure technology has advanced since then!
Thank you again in advance,
Wally.
Re: While we're talking rear ends....How about Lube?? [Re: wkroncke17] #2452779
02/16/18 09:09 PM
02/16/18 09:09 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Now THERE'S a topic name!
Some guys say 80/90 conventional, some 80/140, some say synthetic; let's see how the votes come in.
Re: While we're talking rear ends....How about Lube?? [Re: wkroncke17] #2452792
02/16/18 09:32 PM
02/16/18 09:32 PM
KY
65pacecar Offline
65pacecar  Offline
KY
If you have some of the old Moby_Dick oil that is sealed, the stuff is hard to beat.
Re: While we're talking rear ends....How about Lube?? [Re: 65pacecar] #2452817
02/16/18 10:30 PM
02/16/18 10:30 PM
IN
ahy Offline
ahy  Offline
IN
With a spool no special additive is needed... whale oil or otherwise. For your intended use just about any gear lube - like 80W90 - should work OK.
Sustained high speed running and/or high temps would favor higher viscosity synthetic to take the heat but not an issue on the drag strip. xxW-140.
The last .01 second ET in the quarter mile might favor favor a lighter synthetic like 75W90.
Personally I would probably put 80W-90 in it.
Re: While we're talking rear ends....How about Lube?? [Re: wkroncke17] #2452819
02/16/18 10:40 PM
02/16/18 10:40 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
Thought this was a porn thread.
Re: While we're talking rear ends....How about Lube?? [Re: ahy] #2452894
02/17/18 01:20 AM
02/17/18 01:20 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
quarter mile synthetic 75W90 80W90
Re: While we're talking rear ends....How about Lube?? [Re: topside] #2452922
02/17/18 03:24 AM
02/17/18 03:24 AM
Wisconsin
Wisconsin
Well, since I posted the other thread about the gaske/sealer for pumpkin to housing, I thought I'd stay on the rear end topic.....didn't mean to make everyone think.....well, we all have a one track mind.
So is synthetic needed??
I know I have whale oil, but it been opened. Probably 20 years ago???
Re: While we're talking rear ends....How about Lube?? [Re: wkroncke17] #2452934
02/17/18 04:10 AM
02/17/18 04:10 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Twenty-five years ago I was having a hard time getting the 4.88 pro gears to go past 200 rounds. One of my customers was the Kendal dealer for the aria and he suggested that I use synthetic. The ring and pinion get changed at 450 to 500 pass's now just for PM.
Have a great day
Iowan
"obsolete is neat"
Re: While we're talking rear ends....How about Lube?? [Re: ahy] #2452936
02/17/18 04:14 AM
02/17/18 04:14 AM
iagree
I used Valvoline or Pennzoil 85-90 Wt. petroleum based non synthetic gear oil, CRS now realcrazy , in my old pump gas Duster with a strange 35 spline spool in both the 8 3/4 and the Dana 60 after I bent the stock type 8 3/4 housing up bad enough to pull the welds off of the ladder bar brackets on the passenger side during a run, luckily that happened on the starting line and not later blush work
That car ran mid to low tens through the exhaust on Oregon 91 octane pump swill weighing 3450 lbs. with me in it, no problems on the gear lube ever up
Re: While we're talking rear ends....How about Lube?? [Re: wkroncke17] #2452946
02/17/18 04:56 AM
02/17/18 04:56 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
This is the ultimate green goop!
Re: While we're talking rear ends....How about Lube?? [Re: wkroncke17] #2452948
02/17/18 05:28 AM
02/17/18 05:28 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
You don't need any additive with a spool. Use synthetic oil.
Re: While we're talking rear ends....How about Lube?? [Re: Dave Hall] #2453094
02/17/18 04:29 PM
02/17/18 04:29 PM
My bracket car came with the Redline lightweight shock proof gear oil in it, it had a blown B1 motor on methanol in the car with 5:87 pro gears that had gone 7.84 at above 186 MPH work Those gears look excellent so I bough several gallons of it to use with the used pickup Dana Corp 4:56 street gears I put in it up No noise or problems so far with my little 700 HP bracket motor shruggy
Redline sells several different versions, weights, of their Shock Proof gear oil, good stuff up scope
Re: While we're talking rear ends....How about Lube?? [Re: Cab_Burge] #2453131
02/17/18 05:52 PM
02/17/18 05:52 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I've worked on and own a car with a fabbed rear end with the big filler cap on them. If you look down that filler hole with a flashlight you can't believe how that stuff sticks to everything! It's amazing! up BTW it smells as bad as the regular stuff... fart
Re: While we're talking rear ends....How about Lube?? [Re: 65pacecar] #2453191
02/17/18 08:45 PM
02/17/18 08:45 PM
KY
65pacecar Offline
65pacecar  Offline
KY
I should have read better, didn’t realize you were running a spool. Save the Whales for now and use it on a stock suregrip setup
Re: While we're talking rear ends....How about Lube?? [Re: 65pacecar] #2453236
02/17/18 10:47 PM
02/17/18 10:47 PM
The Sperm whale oil additive is for the clutch type posi, it slicks the plates and steels up so they don't grab and tear up the clutches up
Re: While we're talking rear ends....How about Lube?? [Re: wkroncke17] #2454063
02/19/18 06:50 PM
02/19/18 06:50 PM
Washington
madscientist Offline
Washington
If you are running that gear on the street you need a GOOD synthetic gear lube. If you live in a warm clime year round, you can use a 70w140. If it gets cold use a 70w90...preferably a GL-6 gear lube.
Re: While we're talking rear ends....How about Lube?? [Re: madscientist] #2454316
02/20/18 12:41 AM
02/20/18 12:41 AM
Wisconsin
Wisconsin
GL-6???
Excuse my ignorance if you would please....
Re: While we're talking rear ends....How about Lube?? [Re: madscientist] #2454322
02/20/18 12:45 AM
02/20/18 12:45 AM
Kirkland, Washington
Pacnorthcuda Offline
Please explain how a 70w140 would be appropriate for a warm climate and a 70w90 for a cold.
Please!
Re: While we're talking rear ends....How about Lube?? [Re: madscientist] #2454402
02/20/18 03:33 AM
02/20/18 03:33 AM
OP, I put Red Line synthetic gear oil in my last street Dana with a chrome cover and that rascal leaks out between bottom of the gasket and housing, even with Mopar gear lube silicone work
That cover never leaked with regular gear oil in all the other rear ends I have used them on work
I'll probably end up putting regular petroleum based posi gear 75x90 WT oil back in it with the posi lube additive up
