Re: While we're talking rear ends....How about Lube??
[Re: topside]
#2452922
02/17/18 03:24 AM
02/17/18 03:24 AM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
Now THERE'S a topic name! Some guys say 80/90 conventional, some 80/140, some say synthetic; let's see how the votes come in. Well, since I posted the other thread about the gaske/sealer for pumpkin to housing, I thought I'd stay on the rear end topic.....didn't mean to make everyone think.....well, we all have a one track mind. So is synthetic needed?? I know I have whale oil, but it been opened. Probably 20 years ago???
[Re: wkroncke17]
#2452934
02/17/18 04:10 AM
02/17/18 04:10 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Twenty-five years ago I was having a hard time getting the 4.88 pro gears to go past 200 rounds. One of my customers was the Kendal dealer for the aria and he suggested that I use synthetic. The ring and pinion get changed at 450 to 500 pass's now just for PM.
Have a great day Iowan
"obsolete is neat"
[Re: ahy]
#2452936
02/17/18 04:14 AM
02/17/18 04:14 AM
Posts: 43,124 Bend,OR USA
Cab_Burge
With a spool no special additive is needed... whale oil or otherwise. For your intended use just about any gear lube - like 80W90 - should work OK.
Sustained high speed running and/or high temps would favor higher viscosity synthetic to take the heat but not an issue on the drag strip. xxW-140.
The last .01 second ET in the quarter mile might favor favor a lighter synthetic like 75W90.
Personally I would probably put 80W-90 in it. I used Valvoline or Pennzoil 85-90 Wt. petroleum based non synthetic gear oil, CRS now , in my old pump gas Duster with a strange 35 spline spool in both the 8 3/4 and the Dana 60 after I bent the stock type 8 3/4 housing up bad enough to pull the welds off of the ladder bar brackets on the passenger side during a run, luckily that happened on the starting line and not later That car ran mid to low tens through the exhaust on Oregon 91 octane pump swill weighing 3450 lbs. with me in it, no problems on the gear lube ever
[Re: Dave Hall]
#2453094
02/17/18 04:29 PM
02/17/18 04:29 PM
Cab_Burge
This is the ultimate green goop! My bracket car came with the Redline lightweight shock proof gear oil in it, it had a blown B1 motor on methanol in the car with 5:87 pro gears that had gone 7.84 at above 186 MPH Those gears look excellent so I bough several gallons of it to use with the used pickup Dana Corp 4:56 street gears I put in it No noise or problems so far with my little 700 HP bracket motor Redline sells several different versions, weights, of their Shock Proof gear oil, good stuff
[Re: 65pacecar]
#2453191
02/17/18 08:45 PM
02/17/18 08:45 PM
Posts: 6,710 KY
65pacecar
KY
If you have some of the old Moby_Dick oil that is sealed, the stuff is hard to beat. I should have read better, didn’t realize you were running a spool. Save the Whales for now and use it on a stock suregrip setup
[Re: wkroncke17]
#2454063
02/19/18 06:50 PM
02/19/18 06:50 PM
Posts: 4,457 Washington
madscientist
Washington
If you are running that gear on the street you need a GOOD synthetic gear lube. If you live in a warm clime year round, you can use a 70w140. If it gets cold use a 70w90...preferably a GL-6 gear lube.
[Re: madscientist]
#2454316
02/20/18 12:41 AM
02/20/18 12:41 AM
wkroncke17
Wisconsin
If you are running that gear on the street you need a GOOD synthetic gear lube. If you live in a warm clime year round, you can use a 70w140. If it gets cold use a 70w90...preferably a GL-6 gear lube. GL-6??? Excuse my ignorance if you would please....
[Re: madscientist]
#2454322
02/20/18 12:45 AM
02/20/18 12:45 AM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
If you are running that gear on the street you need a GOOD synthetic gear lube. If you live in a warm clime year round, you can use a 70w140. If it gets cold use a 70w90...preferably a GL-6 gear lube. Please explain how a 70w140 would be appropriate for a warm climate and a 70w90 for a cold. Please!
[Re: madscientist]
#2454402
02/20/18 03:33 AM
02/20/18 03:33 AM
Cab_Burge
If you are running that gear on the street you need a GOOD synthetic gear lube. If you live in a warm clime year round, you can use a 70w140. If it gets cold use a 70w90...preferably a GL-6 gear lube. OP, I put Red Line synthetic gear oil in my last street Dana with a chrome cover and that rascal leaks out between bottom of the gasket and housing, even with Mopar gear lube silicone That cover never leaked with regular gear oil in all the other rear ends I have used them on I'll probably end up putting regular petroleum based posi gear 75x90 WT oil back in it with the posi lube additive
