Any tricks for softening carbon caked onto aluminum? #2450801
02/12/18 06:46 PM
02/12/18 06:46 PM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
I've got some pistons that are caked heavily in carbon, is there anything good I can soak them in to soften things up instead of jumping straight to scraping?
Re: Any tricks for softening carbon caked onto aluminum? [Re: DaytonaTurbo] #2450803
02/12/18 06:51 PM
02/12/18 06:51 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Blast cabinet !!
Re: Any tricks for softening carbon caked onto aluminum? [Re: DaytonaTurbo] #2450809
02/12/18 07:00 PM
02/12/18 07:00 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Scrap the heavy stuff. Solvent or 2+2 + scotchbrite to finish. Good oven cleaner might work well. Never tried it though.
Re: Any tricks for softening carbon caked onto aluminum? [Re: DaytonaTurbo] #2450818
02/12/18 07:19 PM
02/12/18 07:19 PM
carb soup. tho it ain't what it used to be (EPA regs).
Re: Any tricks for softening carbon caked onto aluminum? [Re: DaytonaTurbo] #2450847
02/12/18 08:00 PM
02/12/18 08:00 PM
Canada
onig Offline
onig  Offline
Canada
Lacquer thinner may work.
69 Dart
Re: Any tricks for softening carbon caked onto aluminum? [Re: onig] #2450882
02/12/18 09:15 PM
02/12/18 09:15 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Carb cleaner.
'63 Dodge 330
11.19 @ 121 mph
Re: Any tricks for softening carbon caked onto aluminum? [Re: DaytonaTurbo] #2450929
02/12/18 10:28 PM
02/12/18 10:28 PM
Soak them in soapy water overnight upside down with the top in the water but not into the ring lands tsk Soak and scrape until clean as new up
Do not soak for days though either tsk
Re: Any tricks for softening carbon caked onto aluminum? [Re: Cab_Burge] #2450970
02/12/18 11:06 PM
02/12/18 11:06 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I had been told the same thing years ago.
Re: Any tricks for softening carbon caked onto aluminum? [Re: DaytonaTurbo] #2451002
02/12/18 11:45 PM
02/12/18 11:45 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
paint stripper . the jelly type works good
Re: Any tricks for softening carbon caked onto aluminum? [Re: GY3] #2451023
02/13/18 12:16 AM
02/13/18 12:16 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Originally Posted By GY3
Carb cleaner.
iagree This works for me, let it soak in and light scuff pad takes it off pretty easily.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Any tricks for softening carbon caked onto aluminum? [Re: Silver70] #2451027
02/13/18 12:21 AM
02/13/18 12:21 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I use heat riser solvent and a wire brush, the GM stuff works good.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Any tricks for softening carbon caked onto aluminum? [Re: Silver70] #2451028
02/13/18 12:21 AM
02/13/18 12:21 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Trans fluid and mineral spirits 50/50.
Re: Any tricks for softening carbon caked onto aluminum? [Re: CMcAllister] #2451042
02/13/18 12:58 AM
02/13/18 12:58 AM
Maryland
ro23_j Offline
ro23_j  Offline
Maryland
Agree, Berkebile 2+2.
Re: Any tricks for softening carbon caked onto aluminum? [Re: fourgearsavoy] #2451059
02/13/18 01:40 AM
02/13/18 01:40 AM
OHIO THE HEART OF IT ALL
64hemi330sedan Offline
Gus beer
lol! treed. this stuff works. we sell a lot of it at work. I'm a broken chevy fixer parts supplier.
Re: Any tricks for softening carbon caked onto aluminum? [Re: DaytonaTurbo] #2451065
02/13/18 01:54 AM
02/13/18 01:54 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Diet Coke and Marvel Mystery Oil. Half and half.
Re: Any tricks for softening carbon caked onto aluminum? [Re: Cab_Burge] #2451106
02/13/18 10:29 AM
02/13/18 10:29 AM
Canada
onig Offline
onig  Offline
Canada
Why not the ring lands, what will happen?
69 Dart
Re: Any tricks for softening carbon caked onto aluminum? [Re: DaytonaTurbo] #2451188
02/13/18 02:20 PM
02/13/18 02:20 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
berrymans B12 carb spray will literally melt it right off. It is way better and faster than anything else you can get right now. DOn't get the dumbed down California version, B12-C.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Any tricks for softening carbon caked onto aluminum? [Re: DaytonaTurbo] #2451413
02/13/18 10:22 PM
02/13/18 10:22 PM
Manitoba, Canada
Manitoba, Canada
I'll try giving some of the odds and ends a try. I've got an obsolete 2-stroke engine apart on my desk and the ring grooves weren't bad at all but the underside of the piston is just caked in carbon.
