Re: Any tricks for softening carbon caked onto aluminum?
[Re: DaytonaTurbo]
#2450809
02/12/18 07:00 PM
02/12/18 07:00 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Scrap the heavy stuff. Solvent or 2+2 + scotchbrite to finish. Good oven cleaner might work well. Never tried it though.
[Re: DaytonaTurbo]
#2450818
02/12/18 07:19 PM
02/12/18 07:19 PM
RapidRobert
carb soup. tho it ain't what it used to be (EPA regs).
[Re: DaytonaTurbo]
#2450847
02/12/18 08:00 PM
02/12/18 08:00 PM
Posts: 361 Canada
onig
Canada
Lacquer thinner may work.
69 Dart
[Re: DaytonaTurbo]
#2450929
02/12/18 10:28 PM
02/12/18 10:28 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
Soak them in soapy water overnight upside down with the top in the water but not into the ring lands Soak and scrape until clean as new Do not soak for days though either
[Re: Cab_Burge]
#2450970
02/12/18 11:06 PM
02/12/18 11:06 PM
dartman366
Mt. Vernon, Ohio
Soak them in soapy water overnight upside down with the top in the water but not into the ring lands Soak and scrape until clean as new Do not soak for days though either I had been told the same thing years ago.
[Re: DaytonaTurbo]
#2451002
02/12/18 11:45 PM
02/12/18 11:45 PM
Posts: 2,175 Duloc
The Shadow
Duloc
paint stripper . the jelly type works good
[Re: GY3]
#2451023
02/13/18 12:16 AM
02/13/18 12:16 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
This works for me, let it soak in and light scuff pad takes it off pretty easily.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#2451027
02/13/18 12:21 AM
02/13/18 12:21 AM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I use heat riser solvent and a wire brush, the GM stuff works good. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2451059
02/13/18 01:40 AM
02/13/18 01:40 AM
Posts: 1,134 OHIO THE HEART OF IT ALL
64hemi330sedan
I use heat riser solvent and a wire brush, the GM stuff works good. Gus lol! treed. this stuff works. we sell a lot of it at work. I'm a broken chevy fixer parts supplier.
[Re: Cab_Burge]
#2451106
02/13/18 10:29 AM
02/13/18 10:29 AM
Posts: 361 Canada
onig
Canada
Soak them in soapy water overnight upside down with the top in the water but not into the ring lands Soak and scrape until clean as new Do not soak for days though either Why not the ring lands, what will happen?
69 Dart
[Re: DaytonaTurbo]
#2451188
02/13/18 02:20 PM
02/13/18 02:20 PM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
berrymans B12 carb spray will literally melt it right off. It is way better and faster than anything else you can get right now. DOn't get the dumbed down California version, B12-C.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
