Re: 64 413 in to 69 D200
[Re: BlwnCrcab]
#2450466
02/12/18 01:42 AM
02/12/18 01:42 AM
Guitar Jones
Heads and the cam can always be changed later. I would put it in and see how it does first before changing anything.
[Re: BlwnCrcab]
#2450517
02/12/18 03:57 AM
02/12/18 03:57 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
I would pull all the spark plugs and look very closely at all the ends to check for condensation and rust, if that is good then try rotating the motor over while priming the oil pump. If that goes good, no noticeable tight spots, then look at installing it and running it. Be very careful on the timing, jetting and gas quality with that unknown compression ratio I'm in the middle of building a 413 H.D. truck block into a pump gas 463 C.I. motor(4.250 bore with a 4.150 stroke) for my 1963 Plymouth Fury. I'm hoping it will make a little north of 450HP with the right cam , 440 Source Stealth heads and a Eddy RPM intake with around 10.0 to 1 compression ratio
[Re: BlwnCrcab]
#2451583
02/14/18 08:41 AM
02/14/18 08:41 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
My Dyno mule, a 426 wedge, 11.8-1 with worked over 516 heads,(the only ones I had ready at the time), a small .520 mechanical cam, an old Torquer intake, 750 Edelbrock carb, and 1-3/4" headers made 464hp@5748rpm and 508.5 ftlbs@4296 rpm. You should do fine with what you have.
[Re: BlwnCrcab]
#2451584
02/14/18 08:43 AM
02/14/18 08:43 AM
Guitar Jones
