64 413 in to 69 D200 #2450464
02/12/18 01:38 AM
02/12/18 01:38 AM
IL
BlwnCrcab Online content OP
BlwnCrcab  Online Content OP
IL
not a race car but still a engine question
I have a 64 413 rebuilt 20 years ago?
never run, 30 over cast pistons flat tops
not sure on comp think 10-1
915 heads, stock cam??, dual plane intake
thinking of putting it in 69 D200 truck had 383 in it
should I leave the closed chamber heads on it?
I have fresh set of 452 heads I can use
would I lose any hp compression drop? w452's
also best cam for low end grunt?
not building racer but still want to smoke tires
will be mostly driver, will tow open trailer w my 65D100 swb on it short hauls couple times a year
thanks for any info
carey
Re: 64 413 in to 69 D200 [Re: BlwnCrcab] #2450466
02/12/18 01:42 AM
02/12/18 01:42 AM
Guitar Jones Offline
Heads and the cam can always be changed later. I would put it in and see how it does first before changing anything.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 64 413 in to 69 D200 [Re: BlwnCrcab] #2450517
02/12/18 03:57 AM
02/12/18 03:57 AM
I would pull all the spark plugs and look very closely at all the ends to check for condensation and rust, if that is good then try rotating the motor over while priming the oil pump. If that goes good, no noticeable tight spots, then look at installing it and running it. Be very careful on the timing, jetting and gas quality with that unknown compression ratio work twocents
I'm in the middle of building a 413 H.D. truck block into a pump gas 463 C.I. motor(4.250 bore with a 4.150 stroke) for my 1963 Plymouth Fury. I'm hoping it will make a little north of 450HP with the right cam , 440 Source Stealth heads and a Eddy RPM intake with around 10.0 to 1 compression ratio luck
Re: 64 413 in to 69 D200 [Re: Cab_Burge] #2450857
02/12/18 08:23 PM
02/12/18 08:23 PM
IL
IL
I've had the motor all apart checked and lubed everything
spins fine all clean and ready to go
I need to stop thinking about it and just put it in and go
Re: 64 413 in to 69 D200 [Re: BlwnCrcab] #2450861
02/12/18 08:41 PM
02/12/18 08:41 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
As previously mentioned, I'd drop it in and see what it's like. Good compression, decent heads, mild cam, dual plane.....probably going to be a tire burner as is. Any pics of the truck?
Re: 64 413 in to 69 D200 [Re: WO23Coronet] #2450879
02/12/18 09:11 PM
02/12/18 09:11 PM
IL
IL
one in Rino's shop before leaving
need to take more in my shop
Re: 64 413 in to 69 D200 [Re: BlwnCrcab] #2451480
02/14/18 12:29 AM
02/14/18 12:29 AM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
You will be doing the one wheel peel until you upgrade that 4.10 Dana... penguinwalk
JB Rhinehart, Realist
A-Body's RULE!
Re: 64 413 in to 69 D200 [Re: Rhinodart] #2451523
02/14/18 01:37 AM
02/14/18 01:37 AM
IL
IL
I think I have a sure grip for a Dana sitting on the shelf have to look
Re: 64 413 in to 69 D200 [Re: BlwnCrcab] #2451583
02/14/18 08:41 AM
02/14/18 08:41 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
My Dyno mule, a 426 wedge, 11.8-1 with worked over 516 heads,(the only ones I had ready at the time), a small .520 mechanical cam, an old Torquer intake, 750 Edelbrock carb, and 1-3/4" headers made 464hp@5748rpm and 508.5 ftlbs@4296 rpm.
You should do fine with what you have.
Re: 64 413 in to 69 D200 [Re: BlwnCrcab] #2451584
02/14/18 08:43 AM
02/14/18 08:43 AM
Good looking truck.
