69 B Body carb. spring ? #2448205
02/07/18 09:20 PM
02/07/18 09:20 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
Is this the right carb spring for a 69 Coronet R/T 4 speed.Having a hard time going back to idle at 650.It will stay at 850 unless I pull it back.Fresh build.
Re: 69 B Body carb. spring ? [Re: 5carguy] #2448235
02/07/18 10:30 PM
02/07/18 10:30 PM
BlueRacer69 Offline
BlueRacer69  Offline
I think that is the 1968 spring. The 69 spring is gray in color. If I'm wrong I'm sure others will chime-in and correct me. up
Re: 69 B Body carb. spring ? [Re: 5carguy] #2448269
02/07/18 11:48 PM
02/07/18 11:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
As I recall, they were dark green with a dark red stripe, both years.
Try loosening the carb and moving it around a little, butterflies may be catching the gasket or intake. If the spring needs more tension, shorten it a little bit. I also like a 2nd spring as backup, unless correctness is more important.
Re: 69 B Body carb. spring ? [Re: 5carguy] #2448341
02/08/18 03:46 AM
02/08/18 03:46 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
your prob may be a gummy throttle cable if it is not a new one ?
remove cable from car and flush it good with brake cleaner to free it .
re install it dry do not lube it traps dirt and becomes sticky !
Re: 69 B Body carb. spring ? [Re: 5carguy] #2448349
02/08/18 04:39 AM
02/08/18 04:39 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
EZ to check..
Disconnect throttle cable, and now check throttle action..
Does the idle return back down?
Just my $0.02.. wink
Re: 69 B Body carb. spring ? [Re: 5carguy] #2448672
02/08/18 08:12 PM
02/08/18 08:12 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
I will check the carb gasket,it was a bit tight.The throttle cable is smooth.The spring doesn't seem to be strong enough.Could the vacuum advance be sticking?Just a thought.Thanks for all of the replies.
Re: 69 B Body carb. spring ? [Re: 5carguy] #2448693
02/08/18 08:46 PM
02/08/18 08:46 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Spring attachment is in wrong position, should be on other side of carb linkage.
Not sure what color spring is used for the throttle return but the green spring looks to be the for the trans kick down linkage.
Re: 69 B Body carb. spring ? [Re: B5 Bee] #2449096
02/09/18 02:16 PM
02/09/18 02:16 PM
New York
rarefish Online content
rarefish  Online Content
New York
Here is a engine shot of my unrestored 68 Charger R/T
Re: 69 B Body carb. spring ? [Re: 5carguy] #2449147
02/09/18 04:40 PM
02/09/18 04:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Though the spring is in the wrong position I think the problem is the spring itself , a little too long or not the right specs to pull the throttle fully closed?
ASSuMEing the butterflies are not hitting anything ?
