#2448205 - 02/07/18 06:20 PM 69 B Body carb. spring ?
5carguy Offline
Loc: Lee Co. Fla.
Is this the right carb spring for a 69 Coronet R/T 4 speed.Having a hard time going back to idle at 650.It will stay at 850 unless I pull it back.Fresh build.
#2448235 - 02/07/18 07:30 PM Re: 69 B Body carb. spring ? [Re: 5carguy]
BlueRacer69 Offline
Loc: Michigan
I think that is the 1968 spring. The 69 spring is gray in color. If I'm wrong I'm sure others will chime-in and correct me. up
#2448269 - 02/07/18 08:48 PM Re: 69 B Body carb. spring ? [Re: 5carguy]
topside Offline
Loc: So Near, Yet So Far
As I recall, they were dark green with a dark red stripe, both years.
Try loosening the carb and moving it around a little, butterflies may be catching the gasket or intake. If the spring needs more tension, shorten it a little bit. I also like a 2nd spring as backup, unless correctness is more important.
#2448341 - 02/08/18 12:46 AM Re: 69 B Body carb. spring ? [Re: 5carguy]
calrobb2000 Offline
Loc: s. e. pa.
hi
your prob may be a gummy throttle cable if it is not a new one ?
remove cable from car and flush it good with brake cleaner to free it .
re install it dry do not lube it traps dirt and becomes sticky !
#2448349 - 02/08/18 01:39 AM Re: 69 B Body carb. spring ? [Re: 5carguy]
Sinitro Offline
Loc: So Cal
EZ to check..
Disconnect throttle cable, and now check throttle action..
Does the idle return back down?
Just my $0.02.. wink
#2448672 - 02/08/18 05:12 PM Re: 69 B Body carb. spring ? [Re: 5carguy]
5carguy Offline
Loc: Lee Co. Fla.
I will check the carb gasket,it was a bit tight.The throttle cable is smooth.The spring doesn't seem to be strong enough.Could the vacuum advance be sticking?Just a thought.Thanks for all of the replies.
#2448693 - 02/08/18 05:46 PM Re: 69 B Body carb. spring ? [Re: 5carguy]
B5 Bee Offline
Loc: Pangaea
Spring attachment is in wrong position, should be on other side of carb linkage.
Not sure what color spring is used for the throttle return but the green spring looks to be the for the trans kick down linkage.
#2449096 - 02/09/18 11:16 AM Re: 69 B Body carb. spring ? [Re: B5 Bee]
rarefish Offline
Loc: New York
Here is a engine shot of my unrestored 68 Charger R/T
#2449147 - 02/09/18 01:40 PM Re: 69 B Body carb. spring ? [Re: 5carguy]
JohnRR Offline
Loc: U.S.S.A.
Though the spring is in the wrong position I think the problem is the spring itself , a little too long or not the right specs to pull the throttle fully closed?
ASSuMEing the butterflies are not hitting anything ?
25,742 Registered Members
192,976 Topics
Who makes custom t shirts ?
by 420SIX
02/20/19 04:18 PM
USA source for German made tools
by 360view
02/20/19 03:42 PM
I like trains
by bigdad
02/20/19 03:17 PM
Fiddy Three Dodge w/ Hemi
by Neil
02/20/19 03:02 PM
