Talked to trick flow about new smallblock heads
#2448126
02/07/18 06:26 PM
02/07/18 06:26 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Plan on buying a set and putting them on a zero deck flattop 418 shortblock i have. Have an idea of the roller cam i want to run. They will offer a bolt on ready set of heads that will work perfectly with the cam i have in mind 240/700 pac/ trick flow mechanical roller springs, valves, Ti retainers, cnc, valve job, ready to bolt on and run...... 1099 each the guy told ne If they make the power i hope they do, they should sell a bunch of them at that price point( will be cheaper for flat tappet setup) Should be a 12.7 ish compression motor. Cookie cutter. Single plane, 950, 1 7/8 headers, 904, 8 inch convertor. Hoping for real low 10’s at 3250-3300 pounds not leaning on it to hard. 6500 ish shift point, 4.10 gear, 28 tire. Cam is 259/267 on a 106, 645 gross lift
Re: Talked to trick flow about new smallblock heads
[Re: scottb]
#2448166
02/07/18 07:48 PM
02/07/18 07:48 PM
B3422W5
Portage,michigan
Sounds like a nice set up will they work with your rocker gear No.... spring OD is to big Have to look for rocker gear...... T&D maybe
[Re: B3422W5]
#2448210
02/07/18 09:27 PM
02/07/18 09:27 PM
B3422W5
Portage,michigan
Said September at the worst, hopefully sooner
