Talked to trick flow about new smallblock heads #2448126
02/07/18 06:26 PM
02/07/18 06:26 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Plan on buying a set and putting them on a zero deck flattop 418 shortblock i have.
Have an idea of the roller cam i want to run.
They will offer a bolt on ready set of heads that will work perfectly with the cam i have in mind
240/700 pac/ trick flow mechanical roller springs, valves, Ti retainers, cnc, valve job, ready to bolt on and run...... 1099 each the guy told ne
If they make the power i hope they do, they should sell a bunch of them at that price point( will be cheaper for flat tappet setup)
Should be a 12.7 ish compression motor. Cookie cutter. Single plane, 950, 1 7/8 headers, 904, 8 inch convertor. Hoping for real low 10’s at 3250-3300 pounds not leaning on it to hard. 6500 ish shift point, 4.10 gear, 28 tire.
Cam is 259/267 on a 106, 645 gross lift
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Talked to trick flow about new smallblock heads [Re: B3422W5] #2448161
02/07/18 07:39 PM
02/07/18 07:39 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Sounds like a nice set up will they work with your rocker gear
Re: Talked to trick flow about new smallblock heads [Re: scottb] #2448166
02/07/18 07:48 PM
02/07/18 07:48 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
No.... spring OD is to big
Have to look for rocker gear...... T&D maybe
1.41 best 60 foot
6.56 at 104.17
Re: Talked to trick flow about new smallblock heads [Re: B3422W5] #2448194
02/07/18 09:03 PM
02/07/18 09:03 PM
AndyF Offline
AndyF  Offline
Comp dual conical springs should work with that cam and should clear any rocker arm.
Re: Talked to trick flow about new smallblock heads [Re: B3422W5] #2448203
02/07/18 09:18 PM
02/07/18 09:18 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Did TF have any updates on the release date?
Re: Talked to trick flow about new smallblock heads [Re: B3422W5] #2448210
02/07/18 09:27 PM
02/07/18 09:27 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Said September at the worst, hopefully sooner
1.41 best 60 foot
6.56 at 104.17
Re: Talked to trick flow about new smallblock heads [Re: B3422W5] #2448226
02/07/18 10:16 PM
02/07/18 10:16 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Man i would love to see you with a G3 in your ride. LOL
Matt
