Steering column shaft question. #2447028
02/05/18 07:45 PM
02/05/18 07:45 PM
Omaha
road Offline OP
road  Offline OP
Omaha
Want to verify that one can just change the shaft in a standard steering column to the shorter power steering shaft as part of the conversion to power steering with no other changes to column?
Re: Steering column shaft question. [Re: road] #2447166
02/05/18 11:44 PM
02/05/18 11:44 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Yes. Make sure you have the power steering box coupler as the splined hole in the manual coupler is bigger than a power steering coupler.
Re: Steering column shaft question. [Re: road] #2447193
02/06/18 12:29 AM
02/06/18 12:29 AM
Chicago
PurpleBeeper Offline
Chicago
sixpak is correct. I swapped JUST the shaft in my 70 from manual to power. I did have to get a new coupler though because the p/s box input spline is different than the manual box.
I do recommend you put in new upper bearing & lower bushing while you're at it
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Steering column shaft question. [Re: PurpleBeeper] #2447293
02/06/18 09:15 AM
02/06/18 09:15 AM
Pa
dem0n72 Offline
dem0n72  Offline
Pa
When I had mine apart and broke the pins I just drilled them out and replaced them with a 10/32 nylon bolt and nut.
Re: Steering column shaft question. [Re: dem0n72] #2447319
02/06/18 11:45 AM
02/06/18 11:45 AM
Omaha
road Offline OP
road  Offline OP
Omaha
THANKS all
