#2447028 - 02/05/18 04:45 PM Steering column shaft question.
road Offline
Loc: Nebraska
Want to verify that one can just change the shaft in a standard steering column to the shorter power steering shaft as part of the conversion to power steering with no other changes to column?
#2447166 - 02/05/18 08:44 PM Re: Steering column shaft question. [Re: road]
Sixpak Offline
Loc: The Swamp
Yes. Make sure you have the power steering box coupler as the splined hole in the manual coupler is bigger than a power steering coupler.
#2447193 - 02/05/18 09:29 PM Re: Steering column shaft question. [Re: road]
PurpleBeeper Offline
Loc: Chicago
sixpak is correct. I swapped JUST the shaft in my 70 from manual to power. I did have to get a new coupler though because the p/s box input spline is different than the manual box.
I do recommend you put in new upper bearing & lower bushing while you're at it
Edited by PurpleBeeper (02/05/18 09:31 PM)
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
#2447293 - 02/06/18 06:15 AM Re: Steering column shaft question. [Re: PurpleBeeper]
dem0n72 Offline
Loc: Pa
When I had mine apart and broke the pins I just drilled them out and replaced them with a 10/32 nylon bolt and nut.
#2447319 - 02/06/18 08:45 AM Re: Steering column shaft question. [Re: dem0n72]
road Offline
Loc: Nebraska
THANKS all
25,708 Registered Members
196,868 Topics
Fast / 6
by bigdad
01/23/19 08:09 AM
New G3 hemi Camshaft degree lifter bore indicator tool
by johnscudashop
01/23/19 07:53 AM
Buy A VIN?
by EV2Bird
01/23/19 07:30 AM
Is the Government shutdown effecting you? (No politics)
by MI_Custumz
01/23/19 06:40 AM
