mixing different brands of cams/lifters
#2446694
02/05/18 03:36 AM
02/05/18 03:36 AM
RapidRobert
hyd cam/hyd lifters and solid cam/solid lifters. (got both types in progress) but a different brand of lifters on a different brand of cam. problem or no problem? thank you for your time.
Re: mixing different brands of cams/lifters
[Re: BigBlockMopar]
#2446754
02/05/18 12:07 PM
02/05/18 12:07 PM
RapidRobert
Alright, I will call it good/do all of the caveats/cross my fingers. thanks guys!
[Re: RapidRobert]
#2446960
02/05/18 05:43 PM
02/05/18 05:43 PM
dogdays
Don't be silly. As most lifters come from only a few manufacturers, chances are the main body of Lifter X has the same body as Lifter Y and Lifter Z. Now the internal tolerances may be different, but what meets the camshaft is pretty much uniform from lifter to lifter. Anyhow it's been done literally a hundred million times or more.
R.
Also, most cam cores come from one of two or so manufacturers.
[Re: dogdays]
#2446981
02/05/18 06:20 PM
02/05/18 06:20 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
R.
Also, most cam cores come from one of two or so manufacturers. Most are just repackaged by whatever cam company you use.
[Re: RapidRobert]
#2447198
02/06/18 12:37 AM
02/06/18 12:37 AM
Posts: 957 Chicago
PurpleBeeper
Chicago
You can use different brands lifters/cam. Anyone remember Rhodes lifters? They were supposed to "bleed down" at low rpm to mellow out a larger hydraulic cam. I used them on a 292/509 purple shaft cam with not issue at all.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
