mixing different brands of cams/lifters #2446694
02/05/18 03:36 AM
02/05/18 03:36 AM
RapidRobert Offline OP
hyd cam/hyd lifters and solid cam/solid lifters. (got both types in progress) but a different brand of lifters on a different brand of cam. problem or no problem? thank you for your time.
Re: mixing different brands of cams/lifters [Re: RapidRobert] #2446702
02/05/18 04:33 AM
02/05/18 04:33 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
never had a prob using 30w amsoil break in oil !
Re: mixing different brands of cams/lifters [Re: calrobb2000] #2446705
02/05/18 04:50 AM
02/05/18 04:50 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Done it many times with no problem.
Re: mixing different brands of cams/lifters [Re: RapidRobert] #2446719
02/05/18 09:32 AM
02/05/18 09:32 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I've put a mixed set of used solid lifters on an also used hydraulic cam. Drove around for some 3 years without wiping anything until to upgrade to a roller cam.
But I've also wiped a lobe once on a setup where everything was done by the book.
Re: mixing different brands of cams/lifters [Re: BigBlockMopar] #2446754
02/05/18 12:07 PM
02/05/18 12:07 PM
Alright, I will call it good/do all of the caveats/cross my fingers. thanks guys!
Re: mixing different brands of cams/lifters [Re: RapidRobert] #2446960
02/05/18 05:43 PM
02/05/18 05:43 PM
dogdays Offline
dogdays  Offline
Don't be silly. As most lifters come from only a few manufacturers, chances are the main body of Lifter X has the same body as Lifter Y and Lifter Z. Now the internal tolerances may be different, but what meets the camshaft is pretty much uniform from lifter to lifter.
Anyhow it's been done literally a hundred million times or more.
R.
Also, most cam cores come from one of two or so manufacturers.
Re: mixing different brands of cams/lifters [Re: dogdays] #2446981
02/05/18 06:20 PM
02/05/18 06:20 PM
an8sec70cuda Offline
R.
iagree Most are just repackaged by whatever cam company you use.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: mixing different brands of cams/lifters [Re: RapidRobert] #2447198
02/06/18 12:37 AM
02/06/18 12:37 AM
Chicago
PurpleBeeper Offline
Chicago
You can use different brands lifters/cam. Anyone remember Rhodes lifters? They were supposed to "bleed down" at low rpm to mellow out a larger hydraulic cam. I used them on a 292/509 purple shaft cam with not issue at all.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
